Mistral 27TD
Posted: Tue Nov 27, 2012 8:47 am
by Disco Gofer
Hi guys, I'm sure this topic is some in here but couldn't find it so asking again.
What is the butter fly on the intake for? I saw some where that this gets removed and blocked off? Does this help power or economy or what's the go here?
Also are there any catch tanks for the rocker cover breather that one can buy and fit easily? I'm not too keen to hang a pipe on the road like peeps do cause I have a few motor cycles and don't want slip on intentional oil spils when wet.........
Thanks in advance.
Bernhard
Re: Mistral 27TD
Posted: Tue Nov 27, 2012 8:58 am
by Dirtydog
have a look on trademe for an oild catch can, heaps there,
and the thing your talking about is part of the egr system, there was a thread about 2 weeks ago about blocking it off.
Re: Mistral 27TD
Posted: Tue Nov 27, 2012 11:08 am
by ArvinSlayer
^ exactly as he says!
Peace
Arvin
Re: Mistral 27TD
Posted: Tue Nov 27, 2012 11:47 am
by DEATH_INC
http://www.offroadexpress.co.nz/Forums/ ... 25&t=33198There ya go.
As for the rocker vent, I run mine into the exhaust, it'll burn anything that it blows into there...
What sorta bikes ya got?
Re: Mistral 27TD
Posted: Tue Nov 27, 2012 12:04 pm
by y60 safari driver
the oil only blows out of the breather in large amounts when the rocker shaft is worn, i replaced the one in my safari last year and was only about $500 so the 4 cyliners should be less, means you can actually set your tappets correctly too.
just pull the vacuum hose off the egr and block the hose up, save you having lagging, smoking issues from the egr
Re: Mistral 27TD
Posted: Tue Nov 27, 2012 9:08 pm
by Disco Gofer
Man...thanks for all help guys. Will do and check and fix all the mentioned comments. Should keep my folks rollin for a good few more km's still.
Re: Mistral 27TD
Posted: Tue Nov 27, 2012 9:12 pm
by Disco Gofer
DEATH_INC wrote:http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=25&t=33198
There ya go.
Got an 03 Meansteak 1500 fully custom with green pain job, croc skin seat cover ( don't tell Doc pls....), forward controls, clear lenses and an 08 Suzuki Vstrom 1000 with custom stainless pipes, upgraded lights, HD led. Love em both.
