HDJ81 24v starter issues
Posted: Tue Nov 27, 2012 7:40 pm
Has anyone had anything like this before. Replaced batteries and this started happening. Starter winds over flat out but won't crank engine on first turn of key, makes a good clunk when key is released and starter slows down (noise possibly due to engagement with ring gear). On second attempt at starting fires up straight away.
Pulled starter out pinion looks ok for 220,000kms.
Checked pinion throw out on battery pack on garage floor. OK.
Greased pinion shaft.
I've heard there's a throw out clutch rebuild kit for these.
Any advice appreciated.
