I'm having problem's fitting a lift spring to front right atm, the ball joint connected to the control arm will not allow the knuckle to drop Taken all bolt's off (strut, steering arm ball joint un done but wont release, stabilizer ball joint)
an yes if your thinking it we have try the gentle persuasion technique with large john key friendly hammer
Has any of use with V6 come across this problem or have a trick or two around it?
P.s if anyone's got a spear set of manual locking hubs for the v6 thay want too get rid of PM me....
