Hi have a 85 yn60 surf it has the laps belts in the rear like all the others ive owned and seen, but having two young boys id rather have the sash belt type.
On alot of the U.S sites I see their 4runners of the same age have a factory roll bar with sash belts on them, What im wondering is if I was able to get one of these bars would it be legal or certable being factory? or did they all have them and were removed when they were imported as they were deemed unsafe?
any input would be great.
Thanks Stu
early surf 4runner rollbar/ seat belt mount
Re: early surf 4runner rollbar/ seat belt mount
there is a little history behind the JDM and US surf/4runners and go goes a little like this.
The US government to protect there own light truck market put big tarriffs on imported light trucks , so in order for the likes of nissan toyota and mazda to get around this issue they stopped importing the hilux and started fitting 4/5 seat capability to the hilux surf/ 4 runner with a fibre glass shell added as apposed to the JDM steel body SUV. also why the US 4 runner was a 2 door.
it got imported, stripped the back and rear seats out and you had a "ute" again.
The roll bar wasn't deamed unsafe it was a factory addition. it was cheaper to fit it and seatbelts with a rear seat, then for toyota to pay the tarriff on a 2 seater single cab well side hilux.
Your best bet is(but i doubt it) is to ring around every wrecker of SUV's and see if any surplus 4 runners didn't make it to the states and got sent to NZ instead. other wise try Ebay.
then there is the issue of ensuring your particular hiux surf has the allowances in the body work for said roll bar..... if not then it will need a cert. if the nuts are welded into the body from factory you are good to go roll bar wise, you will still need to look up the rule book on the seatbelts though, they may require you to install brand new ones.
Cool thanks, makes sense, Ive found one
so ill see how I go plan is to put it in and make it look like its always been there, theres already the captive nuts there for it to bolt straight in
bigstu wrote:Cool thanks, makes sense, Ive found oneso ill see how I go plan is to put it in and make it look like its always been there, theres already the captive nuts there for it to bolt straight in
If the nuts are there you are good to go with the bar.
i have one of these roll bars, come out of aussy inport model if you keen im in auckland $100
ToyRover wrote:i have one of these roll bars, come out of aussy inport model if you keen im in auckland $100
Thanks but Ive found one down here in the south island, does your one have seat belts on it?
Thanks Stu
keen to get hold of one myself in the south island. might be a bit costly to get down from Auckland.
anyone know of another one down here
Chris
Chris
Does it have the seatbelt attachments? I was able to make one with some pre bent tubes but no belt holders.
92 LWB Safari TD42
Sorry to jump into the thread...
***BIGSTU*** Have PMd you
92 LWB Safari TD42
