Fixing my 4Y
Posted: Thu Dec 06, 2012 9:24 pm
by Pottzy
Hi, I have had a problem. I managed to hydrolic my 4Y engine and put a conrod out the side of the block.
To get things running again at a cheap price I have purchased a 3Y carb motor to replace the 4Y. My question is would it be a good option to replace the 3Y carb head with the 4Y EFI head off my buggered motor?
Should I try and keep the EFI or go to carb, will the 4Y head fit on the 3Y block?
Thanks for any advice cheers :? :)
Re: Fixing my 4Y
Posted: Fri Dec 07, 2012 5:33 am
by LOLYF
from memory when my truck had a 3y in it the head actually had 4y on it :?
Think may be they use the same head :?: any way i'm pretty sure you will be able to use the 4y efi head on the 3y block and it would be good to keep the efi as its heaps better offroad than a shitty old carb.
Re: Fixing my 4Y
Posted: Sun Dec 09, 2012 8:33 pm
by Pottzy
LOLYF wrote:from memory when my truck had a 3y in it the head actually had 4y on it :?
Cheers that's what I was hopeing. :D
Re: Fixing my 4Y
Posted: Mon Dec 10, 2012 9:56 am
by 3VILC
Keep the EFI for sure. Im in the process of changing my carby 4Y to EFI
Re: Fixing my 4Y
Posted: Mon Dec 10, 2012 10:11 am
by bob_or_jim
Bit of a tread jack here but it may be of use to you guys. I have a 4Y motor with the injection setup on it here that I will be getting rid of very soon. Sing out if ya need any bits (incl loom)
Re: Fixing my 4Y
Posted: Mon Dec 10, 2012 6:35 pm
by Smurf
bob_or_jim wrote:Bit of a tread jack here but it may be of use to you guys. I have a 4Y motor with the injection setup on it here that I will be getting rid of very soon. Sing out if ya need any bits (incl loom)
Where is 'here" could be keen
Re: Fixing my 4Y
Posted: Mon Dec 10, 2012 8:26 pm
by bob_or_jim
Invercargill
Re: Fixing my 4Y
Posted: Sun Feb 10, 2013 8:13 am
by justin
im thinking about it too , got a buggard 3y carb , gota new 3y-e, to replace it , any one got advice?, wiring etc...
thanks
Re: Fixing my 4Y
Posted: Sun Feb 17, 2013 7:01 am
by justin
well just gotta 32/36 webber carb, with the adaptor ,I know efi is better but ill try this out as it was the cheaper option and ive herd the webber carbs are pretty good, should be running this week ,
Re: Fixing my 4Y
Posted: Sun Feb 17, 2013 7:58 pm
by mack
what sort of adaptor did you get for the 32/36 ? ive just gone down the route myself except ive pulled the 3y out droped a crate 4y in then bought a adaptor plate that i had to modify get longer bolts and longer studs then once the 32/36 was on i made up a custom air cleaner bracket and put a 9" air cleaner on now the big thing with the 32/36 is getting your floats right.
Re: Fixing my 4Y
Posted: Mon Feb 18, 2013 4:41 pm
by justin
hi there this is the adaptor i was told will do the job , copy and past this onyo Ebay -
TOYOTA HILUX TARAGO LITEACE HIACE 1Y 2Y 3Y 4Y WEBER 32/36 CARBY ADAPTOR PLATE.
Its 90 buck aussy and im getting the 32/36 webber .
ill post up when its done, hope this helps, oh yea i got my carb for 250 aussy, how much they go for in nz?
Re: Fixing my 4Y
Posted: Mon Feb 18, 2013 5:05 pm
by mack
i got 2 off mates old man by doing a building job for him i bought my adaptor threw a guy in chch
Re: Fixing my 4Y
Posted: Mon Feb 18, 2013 8:37 pm
by bob_or_jim
I still have an EFI setup minus comp here (3Y). Manifolds are bolted to the head still (head is rooted) and has injectors etc. Has loom as well. Come take it away for a box of the brown gold.
Located in Invercargill.
Re: Fixing my 4Y
Posted: Thu Feb 21, 2013 6:54 pm
by 3VILC
Got mine all hooked up, runs a million times better than with the carb, like driving a whole new truck. For a box I would be grabbing it if I had'nt already got the bits :)
