Toyota Prado 90 33s?
Posted: Sat Dec 15, 2012 12:04 pm
by Bj70swb
Hi All,
Reviews of a prado 90?
Im looking at getting a 1997 Prado 90 series, lifting it and putting it on 33s.
It has a 1KZ-TE engine, manual box.
Are the prados any good? Also, what needs to be done to fit 33?
Re: Toyota Prado 90 33s?
Posted: Sat Dec 15, 2012 12:09 pm
by Jerry
90's still have head cracking issues (like other 1kz's) worth doing the dump pipe and big exhaust as well, also centre diff lock is a known weak point on these, permanent 4wd as well. lots of plastic bits on the body to break as well
better off with a earlier 70 series one with beam axle maybe?
Posted: Mon Jan 07, 2013 3:52 pm
by 1justin
90 series are cars with diesel engine problems
stay away from 1kzs if you can help it
soild front and rear axles are more suited for 4wd
an alternative could be a 80 series land cruiser
or a nissan patrol cheaper and more reliable but slowwwww
also to put 33 on a prado ya may have to trim the body a bit witch you may not want to do on a new truck
Posted: Thu Jan 24, 2013 8:17 am
by bob_or_jim
A few of the above issues are correct but I have 1 and love it (not used and my main offroad vehicle) If your intending on doing pretty rough trails then ide go for a 78 or 80 series cruiser but as far as a good mix then these are great. You wont get it on 33's though as they need 16" rims. A mate of mine has his on 265 75 R16's and with a OME lift they rub a tiny bit on full lock. To fix the above issues just beam it...........easy to say I know but it fixes everything. It looses the transfer case and you end up with a solid front.
Anyway hope this doesnt confuse you more
Posted: Thu Jan 24, 2013 11:23 am
by rokhound
I have one on 285/75/18 MT's (slightly over 33"). Ctr diffs are weak as shit. I wouldn't buy one with the intention of being able to use it as a club truck, but for safari style wheeling I guess that would be okay. Mine is only to get the trailer queen closer to the action.
Posted: Thu Feb 28, 2013 10:10 pm
by 2roky
i have the narrow body version.... none of the plastic's to break, factory rear locker im running a set of 265 75 16 coopers and also a set of 33, 10.5 16 silverstones,
standard 2" suspension lift and only get a little front guard rub if i turn and drop off a ledge/bank alittle hot
