Boat buying
For all you fishing nuts
RJT
Boat buying
Post by RJT »
I'm looking at buying my first boat, <5m, for fishing mostly fresh water up the lakes like Coleridge etc. Looking in particular at Marlborough darts and fi glass fireballs. How do people rate these as fresh water fishing boats? Anything in particular to look for when inspecting them? Soft spots etc...
2008 R51, 2.5TD. 265/70R17 R/T's, 1.5" Rancho lift, Ironman snorkel and Deluxe winch bar, SCA 12,000lb winch and 9" LED spotlights, Kings awning, Alpinestar roof box, GME TX3100 UHF.
J_Dub
Re: Boat buying
Post by J_Dub »
i rate them very highly
Ive worked on them a lot.
well built boats, I especially like the darts
Find the 1 you want, all you need is a hammer, tap all over the transom and under the water line on the hull, transom should be hard and when you tap it with a hammer it shouldnt bounce and will have a hard cracking sound if solid or a dull soft sound if the transom is soft and rotten, same as the hull but expect there will be soft spots where there is no stringers, then hard spots where the stringers are. check for hairline cracks, these arent neccesarily bad but if water is seeping out then water is getting in
RJT
Re: Boat buying
Post by RJT »
Excellent thanks for that. Can the same be said about sea nymphs? Had a look at one last night. They're were no soft spots, just a bit of surface crazing on the top sides. But the engine was a peach! Looked damn near new!
waka
Re: Boat buying
Post by waka »
I Have a 52 hamilton with 308 holden in it i maybe interested in selling due to upgrading. It is a perfect lake boat eats 5 easy with heaps of space what kind of $$$ you want to spend?
teamorange
Re: Boat buying
Post by teamorange »
Personally its all about the outboard. Buy one with the newest motor you can afford with the lowest hours and well serviced. I had a Sea Nymph Gullwing V146 (14.5FT) for about 5 years excellent stable boat and very well regarded, the crazy glazing look does not effect the running of the boat but it is expensive to repair so I never bothered.
I bought mine with a 1990 Mercury 90HP with 380+ hours it let me down a few times (which is never a good thing) so then I repowered it with a brand new Yamaha 90HP and never looked back.
Just my 2cents worth
muskie
Re: Boat buying
Post by muskie »
i bought my boat from turners, it was a repossesion and i got it for $5000, its an aluminium fyran 460 with a yamaha 50 2 stroke, it is purely a fishing boat and comfortably fishes 4, this particular model was built in conjunction with that bill hohepa fishing guy....when i bought i took a chance and went on the boats condition as i couldnt run the motor as there was no key, i bought a key from yamaha for $26 and the motor crackled into life first turn, just cleaned out the carbs (today) as it had been sitting for well over a year and its now perfect and worth around $10-$12k i am over the moon with it.. so maybe keep an eye on turners.... i have a turners at the bottom of my road and my boat had sat there for 3 months becouse of the fact noone could start it....it could have easily gone the other way though and i expected it too if i am honest, but as the hull is in great condition i didnt mind buying a newer motor and may even trade this one in as i have had a motor trade in quote of $3500 against a demonstrator merc at $8000...chance you take though.
Return to “Fish'n”
