FS: 1995 Suzuki Escudo
Selling or wanted vehicles.
WH4LES
Stropper
Post by WH4LES »
Just wondering if anyone is interested in my little toy, was going to put it on trademe today and the wheel bearing died today, so that needs fixing, really have no time at the moment, so am just seeing if there's any interest as it is, really needs both front wheel bearings doing, and left engine mount. I will bump the price up if it doesn't sell soon and I get time to fix it.
It's a 95 swb two door escudo, around 150,000ish km's, manual, warrant is around a month old, rego till September 2013,
16v 1.6l, has extractors
now the good parts
Lockrite rear auto locking diff,
Grand vitara steel diff housing in the front,
Low ratio diffs (5.125:1)
Spring lift , 50mm from memory, new Munro rear shocks and some aftermarket big grunty looking ones in the front,
50mm body lift,
30x9.5x15 maxxis buckshot mudders on white 15x8" rims, spare is the same but on a random rim,
Front skid plate and fuel tank guard,
Home made front bull bar with 9500lb winch, wired up to in and out buttons in the cab with relays in a plastic box in engine bay,
Full 6 point roll cage with lvvta cert,
Safari brand snorkel with k&n panel filter,
Nardi steering wheel,
CD player and some speakers,
rear seats removed (certed) with wooden tray and tool box,
Manual hubs,
Underbody has been fully undersealed with 3m underseal, I re did it two months ago.
All carpets removed, alloy check plate floor mates, set up for second battery.
Body is pretty rough, and has seen a lot of trip up the forest, mates farms etc...
Spray painted matt green,
Will add any other bits I remember and photos when I get a chance.
$3k as is
Is in papatoetoe, will need to be put on trailer due the the wheel bearing, it's completely rooted.
Dan
Rochelle
Newbie
Newbie
Re: FS: 1995 Suzuki Escudo
Post by Rochelle »
If you still got your Escudo hanging around I would be interested in knowing a bit more about it. you can contact me on this trademe listing number 546909596 Thanks
