hey guys i am removing a pump from a safari to get reconditioned.
i am sure i have every thing undone and can move the pump round i just cant get it off.
is there something i have to undo at the front of it?
i tried searching on here but couldnt find anything
thanks for your time
td42 fuel pump help
- mayhem1982
Re: td42 fuel pump help
yes remove radiator power steer res, drive belts then remove round front cover on the engine,
in there you'll find the pump drive gear 19mm nut you all so need two long 8 mm bolts to push the gear off the shaft.
don't drop woodrough key in to the sump
- mayhem1982
awesome thanks
