Page 1 of 2
how do i wind back my speedo on a 1991 terreno
Posted: Thu Dec 20, 2012 7:16 pm
by philip121
as a mater of interest hows this done i was told some garages have a electric wind back thing. I dont want to do this but i am interested and sure others would be also
Re: how do i wind back my speedo on a 1991 terreno
Posted: Thu Dec 20, 2012 7:34 pm
by tow99
cough electric drill cough
Posted: Thu Dec 20, 2012 7:39 pm
by philip121
reversable one ha
Posted: Thu Dec 20, 2012 7:40 pm
by mike
I was talking to the chief speedo winderer from the early 2000's for a major car yard in christchurch years ago. He said the best way was to wind it right forward and right round again that way the numbers say lined up. He said as soon as you wind it backwards the numbers are out of alignment. Reckons he was doing everycar coming through the lot :shock: He took one look at my surf and said it had been done, which I confirmed when I took the dash apart to put in the CB and PRS and found some connectors not rejoined :evil:
Posted: Thu Dec 20, 2012 8:42 pm
by Freddy
what yard...give us a clue :lol:
Posted: Thu Dec 20, 2012 8:48 pm
by philip121
the drill is conneted from under car end of speedo cable or do you take dash apart it would be hard on your drill hand hanging onto the drill for hours is there away to place in a frames or holder for the drill and leave it to UNWIND :lol:
Posted: Thu Dec 20, 2012 8:53 pm
by slide
zip tie round the trigger? :lol: zip ties fix everything :P
Posted: Thu Dec 20, 2012 9:01 pm
by Crash bandicoot
8) you place it in a lathe. stops the vibrations too.
Posted: Thu Dec 20, 2012 9:14 pm
by Mudde1
mike wrote:I was talking to the chief speedo winderer from the early 2000's for a major car yard in christchurch years ago. He said the best way was to wind it right forward and right round again that way the numbers say lined up. :
I have to wonder about this. if you are going to wind a modern speedo forward to end up with it showing 50k less using an electric drill, that's 950k you have to wind it forward. if the speedo sits on 200kmh, it would take 4750 hours to do, roughly 6 months. winding the speedo cable in reverse won't work. try reversing and see if the speedo works, it might on a electronic speedo but not a mechanical one.
Posted: Thu Dec 20, 2012 9:21 pm
by ArvinSlayer
Mines a 1990, i took the dash unit out, unscrewed the speedo unit out, with a screw driver, i opened the mount on the back that holds avset of white gears that stop the numbers from being moved externally. Once that is moved , the numbers will jz roll freely, so adjusted it to the value i desire, then placed the white gears back and stashed it back, if you are careful you can do a good job, and it works fine.
Peace
Arvin the local noob
Posted: Fri Dec 21, 2012 8:42 am
by Bubba
All your names have been taken, the speedo cops are on their way.
Posted: Fri Dec 21, 2012 9:18 am
by lilpigzuk
Bubba wrote:All your names have been taken, the speedo cops are on their way.
Posted: Fri Dec 21, 2012 10:17 am
by xj
Piggy, did you take it off the wall and out of the frame to copy it? Or was it a spare print you had laying about just for this purpose?
Posted: Fri Dec 21, 2012 10:51 am
by rokhound
I think you will find he blew it up from his wallet photo XJ :wink: :lol:
Posted: Fri Dec 21, 2012 11:58 am
by quick6
Minimum effort method. Pull the plastic cover off the front, insert a fine blade to the right of the digit you wish to change, carefully twist it slightly to disengage the pins between the numbers, roll over to your desired value and re-assemble.
Posted: Fri Dec 21, 2012 12:54 pm
by The Stranger
Mudde1 wrote: I have to wonder about this. if you are going to wind a modern speedo forward to end up with it showing 50k less using an electric drill, that's 950k you have to wind it forward. if the speedo sits on 200kmh, it would take 4750 hours to do, roughly 6 months. winding the speedo cable in reverse won't work. try reversing and see if the speedo works, it might on a electronic speedo but not a mechanical one.
That, plus how do you explain it when you go to sell and someone does a VIR look up on it?
So what's the gain?
Posted: Fri Dec 21, 2012 1:56 pm
by Kumarakid
quick6 wrote:Minimum effort method. Pull the plastic cover off the front, insert a fine blade to the right of the digit you wish to change, carefully twist it slightly to disengage the pins between the numbers, roll over to your desired value and re-assemble.
+1 for this method, so easy to remove that cover!
Posted: Fri Dec 21, 2012 6:33 pm
by xj
why the phuk is this even being discussed? its illegal, end of story.
Oh hell, what the heck, shall we discuss the fastest method of bypassing security systems too, or how about where the best chop shops are in the country.
amazing
Posted: Fri Dec 21, 2012 7:02 pm
by Dirtydog
maybe the fact that terrano speedos crap out all the times, and the amount of times ive had to replace mine, ring up land transport, get them to send out a new ticket, and while i wait drive a vehicle that is out of road users?
if i could have wound the speedo back, it would have been alot easier, and would have saved alot of time.
the other thing is, if its illegal to wind back the speedo, is it illegal to buy a speedo with far less k's and install it instead?
Posted: Fri Dec 21, 2012 8:42 pm
by Dr_PC
Remember its all entered into the system when OCF or WOF is done, big red flashing lights appear when numbers dont match, As for Terrano speedos always failing, my one did 450,000 kms without an issue, mind you I didn't play with it either
Posted: Fri Dec 21, 2012 9:21 pm
by Ralfie
xj wrote:why the phuk is this even being discussed? its illegal, end of story.
amazing
Apparently Christchurch has good facilities especially for 4WD's.
Posted: Fri Dec 21, 2012 9:42 pm
by wax
Its not in australia. you can buy a new speedo it will show up as lower k,s and they will warn the new owner but the owner after that . Thats why you sell it to your mate first lol
Posted: Fri Dec 21, 2012 9:49 pm
by philip121
yrd you have to remmember at warrent times the miles or kms are recorded so any playing about you would have to take in to consideration
it show as a inconsistent speedo
Posted: Fri Dec 21, 2012 9:50 pm
by lilpigzuk
fawkin newbs....
youngmeisters wont get it :lol:
Posted: Fri Dec 21, 2012 9:51 pm
by CLUMZ1
how about we get rid of FUCK1NG RUCS FOR PASSENGER VEHICLES?
enough cunt7s wind their K's back, the system doesnt work for passenger cars, change the system.
I remember getting fried over my thread of putting a switch into a GQ Safari dash yet all you terrano buggers are encouraging it....
/sorry im drunk.
CLUMZ (with the bottle)
Posted: Fri Dec 21, 2012 9:53 pm
by Dirtydog
fair enough clumz lmao,
i know plenty of people doing it, not myself though, not worth the risks.
doesnt help we get taxed and taxed and taxed for using diesel though......
Posted: Fri Dec 21, 2012 10:01 pm
by zukmeista
If a diesel costs too much to run buy a petrol and quitcherbitchen. :roll:
Posted: Fri Dec 21, 2012 10:08 pm
by CLUMZ1
zukmeista wrote:quitcherbitchen.
wtf is that
Posted: Fri Dec 21, 2012 10:20 pm
by zukmeista
wtf is that
You'll figure it out when you don't have the drunk anymore.
Posted: Fri Dec 21, 2012 10:23 pm
by CLUMZ1
working on that now, actually, drinking more is counterproductive.
