Can anyone tell me how big a job it is to do a rear diff swap? (complete, disc to disc)
Is there a particular order to do things to make it easier ie fit top trailing arms before lowers or vice versa, fit coils before panhard etc etc.
Was going to attack it with a couple of axle stands and a trolley jack, but might just pay to get it done if its awkward.
Dave
Safari diff swap
Safari diff swap
Its easy Dave just un bolt the old and bolt in the new, Nothing to watch out for.
If you leave the brake lines and calipers attached to the truck you can fit them to the new diff and not need to bleed the brakes once it is fitted.
Couple of axle stands and a trolly jack is all you should need. Try and get the back of it high enough so you can wheel the hole diff out from underneath it.
Do you know where the vacuum hooks into?
What solenoids came with it? the nissans ones can be slow you can get mitsubishi solenoids that speed up the engagement a bit.
If you decide to keep your old diff for spares note that the drivers side axles are different lengths by about 5mm.
Thanks for that, might have to give it a go myself then.
Took a few photos of the hoses, I'm guessing you cant do any damage by having them reversed if I get it wrong?
Got pretty much everything I think. Did you just run rubber tubing from the solenoids to the diff, or use that metal tubing along the chassis?
Dave
Dave
I got a few pics of the solenoids etc, but couldn't trace the tubing from the solenoid to the diff. Just unsure what each solenoid is feeding on the diff. I guess I've got a 50/50 chance of getting them right, but would prefer to get it right first time.
If you happen to know which solenoid hooks to which tube, that would be great.
Dave
Dave
