stacking copper washers?
So im in the middle of my +t conversion on td27 , im fitting up the oil feed to the turbo and find that the only banjo bolt i have left is a little too long so the copper washers are not crushing up and sealing properly , could i simply put two washers on each side of the banjo?
Re: stacking copper washers?
or get a shorter banjo?
i wouldnt think it would leak out past two each side, but pays to do it properly, esp being that its the oil lines!
its more of a temporary thing until i can get the correct banjo , i have meant to been painting this thing for weeks now but have been plauged with dramas i just want it running so i can take it to town for painting so i think ill give the double washers a go
so a closer inspection shows that the thread in the filter housing is rooted
i cant catch a break
