WTB asap td27 oil filter housing
Trench_rat
Im in urgent need of a replacement filter housing for td27 , tried to fit oil feed for turbo conversion to find the thread is completely shot and was bunged up with a small bolt and epoxy , no wonder my banjo bolt wouldnt seal. Would really like to get one asap so please get in touch if you can help. this truck will be the death of me
Re: WTB asap td27 oil filter housing
where are you based i have one availible in hamilton,
can courier $60 all up
cheers jase
cheers jase
Trench_rat
im in palmy north , have a local guy checking his shed for me tonight so if that fails i will be in contact
how'd you get on fella?
have you got the correct pump with aneroid as well?
Trench_rat
have found one thanks
aneroid? what?
yeah fancy name for boost compensator,
so your truck smokes less when off boost.
as i imagine you're just winding up the standard pump.
Trench_rat
do you mean the injector pump? in which case yes im just winding up the non turbo pump
