Page 1 of 3
Newbie with a terrano/now Landcruiser!
Posted: Mon Dec 24, 2012 5:34 pm
by terrano
Hi all bought this terrano today, it is my second one, this has has a lift kit and 32" wrangler muddies on it tjm bull bar and some small spotties, today i put some home made flares on it. next on the list will be go for a wof after xmas and fit a snorkel.
Re: Newbie with a terrano
Posted: Mon Dec 24, 2012 5:45 pm
by slide
hey cool username
, just don't sell up and get a t*y#ta
Sweet, theres a wealth of info on here for ya to mill through.
Share any thoughts you have tho, and pictures are worth more than 1000 words. (100 words is getting too many, pictures are easy to read, many words gets tricky
Posted: Mon Dec 24, 2012 7:43 pm
by fullthrottle
Welcome fellow lover of the big T. burp....ah Christmas eve beers taste good.
Which part of the world are ya from?
Posted: Mon Dec 24, 2012 10:02 pm
by terrano
Cheers for the welcome, im from Christchurch
Posted: Tue Dec 25, 2012 8:39 am
by terrano
A question about the terrano, ive noticed it rubs quite bad on hard lock at the bottom rear of the front gaurds, would a body lift kit fix this or would i need to mod the gaurds?
Posted: Wed Dec 26, 2012 12:50 am
by lax2wlg
Nice Terry! I want that front bar! Was that one for sale in Nelson recently?
From my experience with these rigs, you have several options re the rubbing issue.
-adjust the locknuts on the wheels out, this will reduce turning circle but may be enough to clear the guards, keeps cv joints at a reasonable angle too
-try a different wheel offset or rim size
-consider switching to 10.5 width tyres and zero off set rims (factory spec)
-trim the guards slightly
-2" body lift
Do you know what offset/rim width it's currently running?
Posted: Wed Dec 26, 2012 9:23 am
by Dirtydog
id go for trimming the guards if you dont want to worry about certification
Posted: Fri Dec 28, 2012 11:01 am
by terrano
Failed wof on rear part of the exhaust being filled with rusty holes
so getting that replaced tomorrow and she will be all legal
very happy cant wait to take it on its first voyage, just need to invest in some recovery gear first just incase
Posted: Fri Dec 28, 2012 11:06 am
by terrano
Heres a pic after taking it down the ashburton river mouth for a play when i first got it
Posted: Fri Dec 28, 2012 1:05 pm
by Cambo
Nice truck, Have you considered re-doing the whole exhaust? Did mine from the turbo with 2.5", made a massive improvement. There are quite a few posts on here from people that have done the same.
Posted: Fri Dec 28, 2012 1:48 pm
by terrano
If funds aloud i would of, but just trying to get it all road legal first.
Posted: Wed Jan 02, 2013 7:57 pm
by terrano
Passed the wof the other day so she is all road legal
went for a fishing trip up lake Heron up the Ashburton gorge, and had a look up lake emily? aswell, good we trip.
Now im just waiting on a spare tyre to arrive like the ones that are on the truck as it currently doesnt have one
so once that has arrived will be keen to do a couple of trips with you fellas.
Posted: Sat Feb 16, 2013 8:58 pm
by da_scouser
Gday, you maybe interested in a misson at some stage? Ive got a terrano too, see youve been up the ashburton lakes way. awesome place up there. much good 4wding round lake heron?
Posted: Sun May 05, 2013 8:14 pm
by terrano
Hey yeah there are a few places to go up there, some good fishing and hunting provided you can get access from the property owners.
Bit of an update on the Terrano, gearbox shat itself a couple of months ago on a hunting trip so have been "thinking" about getting the gearbox out for the time
and now winter is just about here i thought i better get my arse into gear and get it fixed before some snow arrives. And im getting itchy feet wanting to get out in the bush
So far i have started removing all the bits around the box, drive shafts ect, just trying to figure out how to get the torsion bars out. Im assuming you have to remove the adjuster bolts completly to get them out, will have a go after work any way. Will try and get some pics up aswell while im at it. Will most likely replace the clutch while im at it and a few bushes while its in the air.
Posted: Sun May 05, 2013 11:20 pm
by lax2wlg
Bummer.. manual or auto?
Put a block/jack under the lower control arm to compress the suspension a bit. Unload the torsions by backing off the adjuster bolt completely. Usually you can get a wrench wedged against the transfer case to hold the nut. Once all the tension is released, remove bolt & mark the position of the adjuster relative to the torsion bar. Tap the adjuster off the torsion bar, towards the rear of the vehicle. Remove adjuster, muscle torsion bar out of LCA.
When you reinstall the torsions you may have to re-index them in order to set the ride height, which is just a fancy way of saying moving the adjuster down 1 or 2 splines from the matchmark you made when removing them.
Be very careful when working around torsion bars as they store a tremendous amount of energy
Posted: Mon May 06, 2013 9:04 am
by terrano
Its a manual, its had a bad wine since i bought it so i new it was only a matter of time.
Awesome cheers for the advice. How hard is it to drop the box with just a jack or would you recomened removing the transfer case seperate to make it a bit lighter?
Posted: Mon May 06, 2013 6:41 pm
by sibainmud
Gravity works well for removing old gearbox
Lots to take out to remove them. Can recommend using two jacks and some small ratchet tie straps to help put another one in. You can use the straps to make a cradle that can be adjusted up or down by tying between the chassis rails
Cool looking truck though, but then i have a soft spot for 3drs.
Posted: Mon May 06, 2013 7:48 pm
by terrano
Cheers for the tip will have to give that a go.
Cheers i love the look of them as well, only problem is im running 32x12.5 R15s which no one seems to make any more and the rims are 15x10s, so im thinking i either go for 32x12.5s and a body lift to help them fit or would some 32x10.5 i think they are fit on my rims ok?
Posted: Mon May 06, 2013 9:48 pm
by lax2wlg
Lighter the better IMO. I run factory Lego 15x7 alloys which have 4.5" backspacing, which will allow me to fit 33x10.5 BFGs with no cutting or flares. Thats a really light rim and a really light tyre, but a true 33"
IFS loves a narrower tire/rim
Posted: Mon May 06, 2013 10:11 pm
by terrano
thats why im a bit worried about my rims they are quite a low offset, ill post a couple of photos after work tomorrow, they are a really nice 3 peice rim but may not be suitable for the truck, what offset rims do you use?
Posted: Mon May 06, 2013 10:26 pm
by lax2wlg
I think they're 0 or even positive offset
They were standard on SE V6s, 31s were a factory option
Posted: Sun May 19, 2013 6:23 pm
by terrano
Finally got motivated enough to take the gearbox out of the terrano, was a lot easier than i thought it would be.
Will replace the clutch as well while ive got the box out, anything else i should be looking at replacing while im at it?
This is the box im looking at replacing it with
http://www.trademe.co.nz/Browse/Listing ... =591849933Trying to upload a couple of photos but its saying they are too big even though they arnt
Posted: Sun May 19, 2013 6:45 pm
by kbjj
While you've got flywheel off being faced for new clutch, replace the rear main seal
Posted: Sun May 19, 2013 7:06 pm
by terrano
Yes good call, will do that while im there
Posted: Sun May 19, 2013 8:06 pm
by terrano
Finally fixed the pics
Posted: Thu May 30, 2013 7:28 pm
by terrano
Ordered some bits for the terrano the other day, and they arrived today, new clutch, release bearing, rear main and gear lever boot.
Removed old clutch, wasnt too bad but worth doing while the box was out
Got the fly wheel machined
New clutch
ANNnnd all back togeather, now just waiting on gearbox to arrive and put
Posted: Thu May 30, 2013 8:35 pm
by fullthrottle
Quick question, does it have a spigot bearing for the gearbox input shaft to locate into?
If it does, make sure its also replaced.
Posted: Fri May 31, 2013 10:58 am
by slide
They have a brass bush in back of crank, rather than a bearing. Worth checking as sometimes they get flogged out. With gearbox out its the perfect time to access EGR crossover pipe to remove and blank off. Put a EGT probe in exhaust blank while you there
Posted: Fri May 31, 2013 12:12 pm
by terrano
Yeah i had a look at the bush it seemed fine, was going to replace it but than forgot
hopefully it will be sweet, murphys law though it will shit its self if i dont replace it
And good idea for the EGR will look into that
Posted: Fri May 31, 2013 4:55 pm
by terrano
Replaced the radius? arm bushes today, the old ones were buggered
OLD
NEW
