Using a high lift jack on a terrano
For all Nissan related topics
terrano
Post by terrano »
Where do you use as a mounting point for a high lift jack on a terrano, do you need to custom make points? For changing tyres for example?
lax2wlg
Re: Using a high lift jack on a terrano
Post by lax2wlg »
Sliders.... Hi Lifting is one of the reasons their on my to do list. Factory bumpers seem pretty sturdy for off road protection but I wouldn't hi lift off them.
Or If your truck has a tow bar and you don't want it, you could remove the bumper and cut/grind/drill/reposition the tow bar crossmember to fit between the chassis rails. That's what I did, so now the rear bumper is 4X2 box section, which is a great platform for hi-lifting. Now I just gotta fizz some tube end pieces on to protect the rear quarters.
