where to attatch a uhf aerial??
For all Nissan related topics
Jacko
Post by Jacko »
Hi. Anyone have any ideas as to how and where to mount a uhf aerial on a nissan safari? how much does the position effect radio performance?
gards
Post by gards »
i have mine mounted on the spare wheel rack, you need to have the tip of aerial about 100mm above truck in this position you dont cop any damage to you aerial
mroffroader
Post by mroffroader »
gards wrote:i have mine mounted on the spare wheel rack, you need to have the tip of aerial about 100mm above truck in this position you dont cop any damage to you aerial
yep thats where you see most of 'em. some say in the middle of the roof :roll: but i think you would rip it off a hell of alot...the best place is on the spare wheel carrier or if you get a short arial maybe on the bullbar...if you have one?
BrentC
Re: where to attatch a uhf aerial??
Post by BrentC »
Jacko wrote:Hi. Anyone have any ideas as to how and where to mount a uhf aerial on a nissan safari? how much does the position effect radio performance?
My aerial is tuned - doesn't require a ground plane - about 300mm high and mounted on my left windscreen pillar
The advise I got when looking for a suitable PRS for the cruiser was
I'm a GME Electrophone fan! A TX3200 is all you need. As for the aerial I'd suggest getting a flexible topped mopole (CD51-68-70) from RFI in Auckland.
albundy
Rolly Polly
Post by albundy »
Mine's mounted at the rear on the roof in an area that I assume was meant for a telephone aerial. It is protected from damage by the roofrack. It has one of those gps units linked into it, that aerial is mounted in the centre on the dash to find the satelites, it had to be totaly opposite the radio aerial.
Al
Elmo
Post by Elmo »
I mounted my ariel in the same place, but on opposite guard to the car stereo ariel. This way I can down my stereo ariel and have them at about the same height, purely for cosmetics.
Its a stainless steel whip with coil at base, its very flexible.
Center of roof is definitly the best place for reception, but not for looks, or security on a 4x4.
I wouldnt have thought on a spare wheel carrier, or bull bars would have been a very good place for reception, as all ariels need a good ground plan to aid with good reception, but hey, we arent talking about very long range comunications here.
The idea when it comes to mounting an ariel is: have a good metal ground plan, keep the coax as short as possible.
Ken
