help needed please
uwish
help needed please
Post by uwish »
Hi guys
im from chch and came over to west coast to do some 4wding over last couple of days but, the trusty hilux has let me down.
short of it is, i had a front brake caliper fail(pistons seized on) and front wheel bearing collapse,
if anyone in christchurch or west coast (greymouth/lake brunner area) has these parts would be great :
the part of an asin fwh that slides onto the axle (the collar) or complete fwh
and a front brake caliper left hand or pair for front. its the vented disc model
the hilux is a 1990 double cab beam axle front (like the rest of nz has)
ive got ifs surf calipers at home and they are not the same.
if you have any of these bit could you please text me and ill ring you(could then pxt or email photo of parts if needed)
if in chch i could get a mate to pick up and then he can courier to me over night so they could be here tuesday (im currently on west coast) ive got till wednesday before i really panic as partner has flight out of chch thursday.
also im on limited internet through cell phone
any help would be great
cheers ben PH/TXT 021 107 4083
mayhem1982
Re: help needed please
Post by mayhem1982 »
hi, call gary on 03 3856033 he should be able to sort you out.
Petemcc
Post by Petemcc »
surf callilper off any 130 should fit ok even if not exactly the same may just need to smooth the edges depending on what rims you are running
Pete
uwish
Post by uwish »
Ok so after pulling apart more and finding more damage.I've managed to get sorted on getting back to chch, but my best and cheapest bet is to replace whole front axle fwh to fwh so if anyone has a complete front axle with or without a 4.5 diff head let me know cheers Ben
uwish
Post by uwish »
Does anyone have a single asin hub or parts of one they want to sell? 30 spline
Thanks
rob-mu
Post by rob-mu »
What parts do you require
niblik
Post by niblik »
Would it be easiest to come collect you with a braked car trailer and haul ya rig and yourself back to chch?
uwish
Post by uwish »
Thanks for the offer but I've got truck back in chch, drove back on Thursday with car trailer and picked up. Parts I need is the centre back part or hub that goes onto cv the you put the cir clip on
rob-mu
Post by rob-mu »
If its the inner hub gear your in luck as I just went to longfields,0275136680 give me a text and I will come have a look
Rob
