surf dash lights wont go off
Posted: Tue Jan 15, 2013 9:23 pm
by mayhem1982
have just done crank seal and cambelt etc on my ln130 surf with a 2lte in it.
i have got it back together and it is starting/running fine.
only problem is all the dash lights stay on and that annoying beep stays on.
anyone got any ideas?
Re: surf dash lights wont go off
Posted: Tue Jan 15, 2013 9:32 pm
by jonossiksilvia
did you touch the alternator at all? belt to alternator tight? id be looking at anything electrical u touched while doing the work
Posted: Tue Jan 15, 2013 9:35 pm
by mayhem1982
i only loosened alt to get the belts off, then tightened belts again to put back together
Posted: Tue Jan 15, 2013 9:40 pm
by jonossiksilvia
mate had his alternator belt slipping everytime he went in water and would do the same thing. ln130 also. problem went away once i tightened his belt.
perhaps its one of those moments where you touch something and something else fails at same time causing 1 hell of a headache
Posted: Tue Jan 15, 2013 10:15 pm
by mayhem1982
yeah, think i might have figured out my deep cycle battey might be flat.
have both batterys on charge over night and will check again in the morning.
i think it might be time to purchase a multi-meter
Posted: Wed Jan 16, 2013 9:35 pm
by mayhem1982
so i had another play with it tonight, starts and runs ok still, alt is working and charging both batteries so my next guess is ignition barrel? its doing my head in
Posted: Wed Jan 16, 2013 9:41 pm
by vvilly
when my alternator brushes were on way out it put all my dash lights up
have ya looked at them
Posted: Wed Jan 16, 2013 9:48 pm
by mayhem1982
alternator was fully rebuilt 6 months ago so hopefully its not that.
might be easier to just take it back and get them to check it, as i have no idea how to check bruches etc
Posted: Thu Jan 17, 2013 4:17 pm
by mayhem1982
turns out it is the regulator in the alternator, just out of warrenty too
