No dash lights, no start. help?
Posted: Sat Jan 19, 2013 11:32 am
by tark
Righto, hi i have just put in a new Alternator.
Once finished i went to fire the ol tart up, theres no dash lights,yet batterey light is on, have checked all fuse's i know of (under hood and in cab) have rechecked all plugs etc. I've spent the last day google ect and i'am still a little lost on it.
Cheers for any help.
Btw it a 2.8 1991 ln106
Re: No dash lights, no start. help?
Posted: Sat Jan 19, 2013 11:47 am
by Smurf
Is it turning over?
Posted: Sat Jan 19, 2013 1:44 pm
by tark
Nope, no clicking, Not a thing....
I was thinking Fusible links, yet i've tested what/were i think i need to for that, but then again i may have not done that right?
Posted: Sat Jan 19, 2013 2:23 pm
by waza4x4toy
any further luck?
Some suggestions for you
Did you disonnect battery when changing alt was there a spark or short on alt feed during process then could be a fusible link, Fuse links - these need to be checked at both ends as may look intact but be blown in middle. Test light is good for this or a volt meter
Are all connections/plugs remade correctly at alternator?
Check do you have 12v at alternator main feed, do you have 12v across battery terminals if bat termnal were removed have these remade good connection or did you leave a minor battery lead disconnected off these?
Posted: Sat Jan 19, 2013 2:40 pm
by tark
Thanks Got it sorted,was under my 60a fuse.
Posted: Thu Jun 27, 2013 12:15 am
by fish
hi i know this is an old thred but i have the same issue. kind of.
no dash lights except battery and the glows dont seem to be working as it turns over for ages before starting. ideas? 2.8 toyota hilux
Posted: Thu Jun 27, 2013 7:59 am
by Smurf
I would check for a blown heavy bolt in fuse in the fuse box under the bonnet?
