lights no work
long
lights no work
Post by long »
Hi guys 1995 JC when ignition is switched off lights work hi n low beams all ok.
When we turn the ignition on only hi beam works if u use the flasher other wise its park lights only .
Anyone have any ideas for a fix.
Terrano TD 2.7 and a ssangyong Rexton
kbushnz
Re: lights no work
Post by kbushnz »
Yeah, put it in the bin and buy a Toyota :lol:
You might have a bad earth somewhere....
long
Re: lights no work
Post by long »
:shock: but its American n we all know they out last jappas ay lol.
sweet will check out earth side of things n c whats up there
nzlux
Re: lights no work
Post by nzlux »
I had the same problem with a motorbike once, it was the ignition switch that was the problem.
Dirtydog
Re: lights no work
Post by Dirtydog »
sounds like bad earth or bad wiring somewhere, which could be the ignition switch.
in behind the ignition you should find a plug that goes into the back, make sure nothing is loose etc, or replace it all together.
mudlva
Re: lights no work
Post by mudlva »
Dirtydog wrote:sounds like bad earth or bad wiring somewhere, which could be the ignition switch.
the jeep that is not the plug :lol: :lol: :oops:
Dirtydog
Re: lights no work
Post by Dirtydog »
:lol: :lol:
long
Re: lights no work
Post by long »
found the problem it needs a new relay anyone hav one they want to sell numbers r 56009324 - 39754-D.
If it was mine i would sell the sucker don't u worry but its son n laws
Return to “Jeep”
