Torque Settings for a 1998 Nissan Terrano R-XR.TD27(EFi)
Posted: Sat Jan 26, 2013 10:03 am
by crowbay
Can anyone supply theTorque Settings for a 1998 Nissan Terrano R-XR.TD27(EFi) I've just bought a new head but can't find settings anywhere for the head bolts etc.
Re: Torque Settings for a 1998 Nissan Terrano R-XR.TD27(EFi)
Posted: Sat Jan 26, 2013 11:29 am
by Crash bandicoot
Tighten all the bolts from the middle of the block working your way out.
1st - 39-44 nm
2nd - 54-59 nm
3rd - turn exhaust side cylinder head bolts 90 degrees clockwise
Posted: Sat Jan 26, 2013 2:03 pm
by crowbay
Crash bandicoot wrote:Tighten all the bolts from the middle of the block working your way out.
1st - 39-44 nm
2nd - 54-59 nm
Thanks for that. Any set pressure for rocker shaft and manifolds?
Posted: Sat Jan 26, 2013 10:04 pm
by sibainmud
Tighten in an even rotation and stop when your elbow clicks.
Trick with any mating surfaces with a gasket is even and frim, not too tight and not too loose
