Boost controller
Posted: Wed Jan 30, 2013 7:25 pm
by a80crewza
Hi everyone, can someone please put up a pic of where they plumbed their manual boost controller on a 1kzte and/or instructions on how to do it?
Thanks.
Re: Boost controller
Posted: Wed Jan 30, 2013 9:02 pm
by Heath
Do a search on Pradopoint forum.
Basically you put it in the line between the inlet turbine and the waste gate. I hope you have small hands and a sense of humour cause it can be a bitch of a job.
Posted: Thu Jan 31, 2013 7:36 am
by kbushnz
You see that little black tube on the turbo...
You need to interrupt that line and plumb in the boost tap....
Its a real pain in the butt to do but is doable. Expect skinned knuckles and a few swear words...
Its better to use new longer hose and get it out into the engine bay area.
Posted: Thu Jan 31, 2013 8:10 am
by a80crewza
Thanks. So if I follow this one (Mines the same controller, except he's modded his t piece)?
http://www.youtube.com/watch?v=wFIGXfZpjgQ
Posted: Thu Jan 31, 2013 8:14 am
by kbushnz
Yup that's the one....except for his mods...
Posted: Thu Jan 31, 2013 2:56 pm
by a80crewza
Okay, hopefully i've done this correctly..
I'm going to extend the black hose into the cabin so I can adjust from drivers seat..
Tell me if Ive done something wrong
Okay, just relised ive done something wrong, the black tube and the wastegate tube need to swapped around.
Posted: Thu Jan 31, 2013 9:18 pm
by skidmark
Just a note incase you don't already know, Im pretty sure with standard inj.pump if you go over/at 14psi they computer will fuel cut, someone maybe able to confirm this...
Posted: Thu Jan 31, 2013 10:44 pm
by kbushnz
skidmark wrote:Just a note incase you don't already know, Im pretty sure with standard inj.pump if you go over/at 14psi they computer will fuel cut, someone maybe able to confirm this...
Yes that is correct...
Posted: Thu Jan 31, 2013 10:52 pm
by kbushnz
luxsurf wrote:Okay, hopefully i've done this correctly..
Yes it did look wrong... Swap them over...
Also you might find you need to remove the check valve in the Tee piece...
I did with mine....as it was better without it... But try it both ways...
The open end on the controller will vent so put a hose on it and send it back into the engine bay.....
