changing bodys ln130 - kzn130
mayhem1982
Post by mayhem1982 »
have done a quick search and think it should be straight forward.
i have a ln130 with a good body and a kzn130 with a good motor and box.
i am assuming it should be pretty straight forward to swap the body over ( was planning on doing a small body lift at the same time.
i presume the bodys are the same?
any hidden surprises i should know about?
thanks for your time.
J_Dub
Re: changing bodys ln130 - kzn130
Post by J_Dub »
exzackery the same, just different motors
vvilly
Post by vvilly »
And wiring including general wiring ie tail lights etc
The whole loom needs to be changed
mayhem1982
so is the loom change just a simple unplug then plug back in?
