Weird jumpy speedo
a80crewza
Weird jumpy speedo
Post by a80crewza »
Hi all. My speedo bounces back and forth a tiny bit at around 3000rpm, its hard to notice. Doesn't do it all the time, and have only noticed it when going high speeds (80-100ish). Seems to come in just before gears change from 3rd to 4th (1kz auto). I just installed a manual boost controller.. Any ideas?
Cheers.
Re: Weird jumpy speedo
may last a year
may not
eventually it will just stop working all together
mine was doing the same till it stopped working, been that way for over 4 years now :wink:
a80crewza
Post by a80crewza »
So its just an ageing gauge :?: Will just have to use the car in front as a speed gauge :)
tweake
Post by tweake »
some of them are quite prone to corrosion on the speedo boards and dry solder joints. fairly easy fix.
Dirtydog
Post by Dirtydog »
just use a gps, easiest way to tell what speed ya doing...
Ollie_216
Stropper
Post by Ollie_216 »
I had a really jumpy speedo on my '94 Surf, would sometimes sit on zero then go to 80 when I was only going 50. Was caused by the sun heating the top of the dash and speedo circuit board, it just melted two solder strips together on the speedo circuit board. I just got a nail and scratched between the two to break the contact. Easy 30min fix with no cost, if that's the problem..
a80crewza
Post by a80crewza »
Okay, so I started my truck up this morning and the engine revs up and down by itself? :shock: Seemed to go away when it started to get warm. So it's not the speedo? Could it be avacuum leak??
