The opinions and viewpoints expressed by users of Offroad-Express Forums are wholly their own and not necessarily those of Offroad-Express. https://www.offroadexpress.kiwi:443/Forums/
Alright I have got myself a 94 td27 Terrano, but I cannot find the egr. Can someone show me a photo of where it is located?
Bear in mind I am a complete novice...
Cheers.
Re: TD27 Egr
Posted: Thu Feb 07, 2013 9:58 pm
by lax2wlg
Hi, this is from the R20, same engine sans intercooler. Should give a general idea.
Re: TD27 Egr
Posted: Fri Feb 08, 2013 6:46 pm
by Mckev
Hey sorry I still can't find it. I am probably looking at it, but just don't know it...
Re: TD27 Egr
Posted: Fri Feb 08, 2013 7:00 pm
by kbjj
Mckev wrote:... but I cannot find the egr...
Why do you want to remove it? You really need to understand what it is and does before randomly remove bits. EGR stands for Exhaust Gas Reticulation System. For it's removal, you need to block/remove the exhaust egr valve (under back of intake manifold) by spading/plateing, then tie open the intake butterfly or remove then block pivot holes, and block off the associated vacuum lines. Hope this helps Jeremy
Re: TD27 Egr
Posted: Fri Feb 08, 2013 7:16 pm
by Mckev
I never said I wanted to remove it. Well, maybe not just yet. Just looking out of curiosity, trying to understand what everything is. I've read a lot on here about blocking the egr off, just wondering whether or it it has already been done to mine.
Re: TD27 Egr
Posted: Fri Feb 08, 2013 7:29 pm
by kbjj
Mckev wrote:I never said I wanted to remove it.
Whoops... my bad. Look for the vacuum operated valve (like one shown in pic) under fire wall end of intake manifold, and see if a 'spade' plate has been slide inbetween flanges to block. A metal pipe runs from this valve around the back of the head, to the exhaust manifold. It bleeds exhaust gases back into intake (intake butterfly assists this) under certain conditions, engine temp, revs, and throttle position are factors. Usually system causes intake to gunge (is that a word?) up, or no longer works correctly and affects performance. Jeremy
Re: TD27 Egr
Posted: Fri Feb 08, 2013 8:16 pm
by Dirtydog
kbjj wrote:
Mckev wrote:Usually system causes intake to gunge (is that a word?) up, or no longer works correctly and affects performance. Jeremy
What now use it all the time
Re: TD27 Egr
Posted: Fri Feb 08, 2013 8:35 pm
by Mckev
Can someone point it on this? What I need is a full engine diagram or someone to teach me this stuff in person ahah.
Re: TD27 Egr
Posted: Fri Feb 08, 2013 8:45 pm
by Dirtydog
this thing is what your looking for, look behind the head down the firewall and you should find it.
Re: TD27 Egr
Posted: Fri Feb 08, 2013 8:49 pm
by Mckev
How far down is it? I thought that was what I was looking for, but I haven't seen anything that resembles it... Haha it probably has been removed...
Re: TD27 Egr
Posted: Fri Feb 08, 2013 8:54 pm
by Dirtydog
i think thats the top of it there, its quite hidden away under heaps of things.
Re: TD27 Egr
Posted: Fri Feb 08, 2013 8:58 pm
by Mckev
Ah ok cheers. I had to climb up onto my nudge bar to even see it.
Re: TD27 Egr
Posted: Fri Feb 08, 2013 9:01 pm
by Dirtydog
least yours isnt as high as mine is lol, sometimes i have to get a chair just to get onto my nudgebar lol
Re: TD27 Egr
Posted: Fri Feb 08, 2013 9:10 pm
by kiwipete
I'm going to check mine out tomorrow as I think mine is still there, although the vaccy hoses have been removed by the engine people ages ago. If it is still in there does it still need removing?
Re: TD27 Egr
Posted: Fri Feb 08, 2013 9:27 pm
by Dirtydog
im thinking of taking mine out, dont know yet.
Re: TD27 Egr
Posted: Fri Feb 08, 2013 9:45 pm
by kbjj
Personally I'd remove or "spade" flange, as valves can stick partially open (with all that gunge), then at least tie intake butterfly open and remove, then block vacuum line.
Re: TD27 Egr
Posted: Sat Feb 09, 2013 1:46 pm
by hamboy
Total removal is fairly easy i just made some blanking plates and bolted them in place. I also removed the butterfly housing and made my own because i wasnt fond of the oil leaking out of it under boost
Re: TD27 Egr
Posted: Sat Feb 09, 2013 2:06 pm
by kiwipete
kiwipete wrote:I'm going to check mine out tomorrow as I think mine is still there, although the vaccy hoses have been removed by the engine people ages ago. If it is still in there does it still need removing?
Yearp, mine is still in there, another project to tackle. All the vaccy hoses have long been removed off it all the same. Has anyone any drawings for blanking plates for it?
When I removed mine, the egr pipe was so caked up it was completely blocked. Even jabbing at it with a screwdriver didn't clear it. I removed mine so I could use manifold end to install EGT probe. A ball bearing wedged into the vacuum line would stop it working, and visually no-one could tell... Probably one reason why there's no law against removing it...
Nath
Re: TD27 Egr
Posted: Sat Feb 09, 2013 3:16 pm
by Dirtydog
i might do the same when it comes to removing mine for the egt guage.
seems an easier option than drilling and tapping into the manifold.
