80 series injector clean, will it work
Posted: Sat Feb 09, 2013 7:50 am
by skid
been putting off the need to clean the injectors for a few years now and still I am nowhere close to having the stupid amounts of money required to clean them
BUT......................
I have been told of a cheap trick involving pure injector cleaner into a new fuel filter and start her, injectors are cleaned and away you go
thoughts please
Re: 80 series injector clean, will it work
Posted: Sat Feb 09, 2013 8:18 am
by SV1K
skid wrote:been putting off the need to clean the injectors for a few years now and still I am nowhere close to having the stupid amounts of money required to clean them
thoughts please
I did that on my Safari and it does work, one in the new filter and another one in the tank, seems to clear and clean them well, was a big cloud of black smoke when I did it too.
Reece
Posted: Sat Feb 09, 2013 8:38 am
by Jerry
there was a place in aus that did new injectors for around $100 don't have the link handy at the moment
Posted: Sat Feb 09, 2013 11:03 am
by geckoadventure
thoughts please
If you have left them for years them doing anything but replacing them will not work. Once they get beyond a certain gummed up stage they have to be replaced.
They also need to be checked to make sure the tips/nozzles are spraying correctly and not out of one side etc making your piston hot one side and cold the other leading to PISTON failure etc.
Posted: Sat Feb 09, 2013 4:29 pm
by mike barnett
just had my injectors recoed by ROD WALFORD most imprest . fast ,cheap,and full of info and addvice gret service way better than and cleaner .
amwalford@xtra.co.nz. 021163821.
Posted: Sun Feb 10, 2013 6:29 am
by mudtroll
mike barnett wrote:just had my injectors recoed by ROD WALFORD most imprest . fast ,cheap,and full of info and addvice gret service way better than and cleaner .
He's just done mine too, nissan, great service.
Posted: Sun Feb 10, 2013 7:05 am
by Jerry
theres a few threads on the net about adding 2 stroke to your diesel lubricates pumps and cleans injectors ...
Posted: Sun Feb 10, 2013 8:44 am
by crazyclark31
two stroke oil is good for lubing the pump and quieting the injectors as well as keeping them clean but if the injectors are dirty/worn then it will only quieten them down(alot).
Posted: Sun Feb 10, 2013 11:45 am
by red-devil
how much 2 stroke do u add
Posted: Sun Feb 10, 2013 12:20 pm
by DaveM
I've run 200:1 in my Safari's for the last few years.
Posted: Sun Feb 10, 2013 2:01 pm
by crazyclark31
[quote="DaveM"]I've run 200:1 in my Safari's for the last few years.[/quote
Just don't use the synthetic or flash race oils. The cheapest stuff is the best.
I average about 300mls a tank. It doesn't have to be exact but 200:1 is the recomended amount
Posted: Sun Feb 10, 2013 8:38 pm
by mudbugga
These guys in Aussie are really good to deal with and cheaper than anyone here in NZ.
http://hiflo.com.au/fuel_injectors_list.cfm?vm=TOYOTA
Posted: Mon Feb 11, 2013 6:00 am
by mudtroll
No their not, got TD42 done cheaper by Rod
Posted: Mon Feb 11, 2013 11:33 am
by badnuz
my ole 80 had terrible knock and smoke issues, once new (re-con) injectors were fitted it had bucket loads more go and way less smoking...
but alas, not cheap.... who-ever you use lol
Posted: Mon Feb 18, 2013 5:20 am
by strx7
1HDT injectors are 2 stage and there is only 2 places in NZ that can recon them properly.
Posted: Mon Feb 18, 2013 10:32 am
by hippy_
strx7 wrote:1HDT injectors are 2 stage and there is only 2 places in NZ that can recon them properly.
Who would that be??
Posted: Mon Feb 18, 2013 11:55 am
by strx7
Alltech in Auckland and a company in Dunedin/Timaru from memory.
Posted: Mon Feb 18, 2013 12:08 pm
by DieselBoy
Diesel, Turbo and Automotive and Waikato Turbo Diesel in Hamilton will do them.
They use a rebuild kit which saves the mucking around with the settings. The kit has some fancy doohickys that preset everything.
Posted: Mon Feb 18, 2013 4:08 pm
by DaveM
Had mine done in Nelson at a Diesel specialist
Posted: Mon Feb 18, 2013 7:46 pm
by SV1K
Talk to Wade at D N T in Petone, he may be able to assist you....
Posted: Mon Feb 18, 2013 9:05 pm
by reddog40
Try water injection, the best water comes from the whakatiki river.
Posted: Mon Feb 18, 2013 9:18 pm
by SV1K
reddog40 wrote:Try water injection, the best water comes from the whakatiki river.
Bawhahahahahaha yeah that place is good for your Skiddy
