1993 mu bar work
Posted: Sun Feb 10, 2013 8:01 am
by nissannut
hi i am after some bar work for my new mu
over time i plan onlifting the body and suspension and fitting front bull bars with winch and rear bull bars and rockslide rails and maybe diff lockers
any hint or idea welcome or pity falls to watch out for
thanks
Re: 1993 mu bar work
Posted: Sun Feb 10, 2013 8:42 am
by Drurban
Hi nissannut,
I have a 1997 Isuzu Mu and have pretty much done all the things you mentioned above.
Also were is your location as I could pop over if you are in Auckland?
Posted: Sun Feb 10, 2013 10:28 am
by nismo26
You might want to do the body lift before the bar work
Posted: Sun Feb 10, 2013 10:40 am
by Sadam_Husain
nissannut wrote:any hint or idea welcome or pity falls to watch out for
thanks
yep probably best to sort out all your body lift stuff before you do the barwork so you dont have to get it all redone again to match the bodylift
edit* opp's missed nismos post above
Posted: Sun Feb 10, 2013 5:52 pm
by nissannut
thanks for the offer Drurban but i live in palmy. and yes i will be doing body lift first.
how much did you lift yours and did you did to make any of the brake lines or wiring longer etc
Posted: Sun Feb 10, 2013 9:28 pm
by Drurban
nissannut wrote:thanks for the offer Drurban but i live in palmy. and yes i will be doing body lift first.
Like the above post's do body lift then bar work, as I found out.
I did a 75mm body lift all is sweet apart from the steering this needs to be made longer were it comes out of the power steering box and in the slip joint. and the mounting of the radiator needs to drop down, everything else I just made it with the brake lines and wiring was not an Issue.
Posted: Tue Feb 12, 2013 6:46 pm
by nissannut
did you build all your bar work? or was it after market.
any hint on what mite be helpful would be great.
Posted: Tue Feb 12, 2013 8:33 pm
by Drurban
nissannut wrote:did you build all your bar work? or was it after market.
My friend on here madlux did my bar work and I must say he did a great job on it.
Cannot get many after market stuff for the Isuzu Mu or you have to do some very extensive searching on the internet to find something also depends on what part you want.
All aftermarket stuff that is avalible easy is FOR NISSAN, TOYOTA, JEEP etc
I suggest go to the Club Isuzu website lots of info on there for the Mu, Bighorn etc.
Posted: Wed Feb 13, 2013 12:37 pm
by nissannut
yes it seam that way . but it ok i like have thing different from the rest of world
i picked up a 100 mm lift kit.
extended leaf spring shackles.
the fibreglass back cover to turn it in to a two seater Ute
yesterday of trade me for a great price
a old mate who is engineer said he will help me build the bar work up.
so over the next few months it will start to come together and evolve
next thing to finded is a winch and get a wof so it sort of road legal till i finish and get it certed and the next wof
