Terrano engine mounts
For all Nissan related topics
kiwinoz
Post by kiwinoz »
I need a new RH engine mount, the local shop here isn't much help and frown about "grey imports".
The best they can do is hope it's the same as for a D21 Navara TD27. I'd rather make sure before parting with $60 plus freight, possibly another $60 to where I am.
Does anyone have a parts calalogue? online or not.
Should be an easy job at the moment, not much left attached to the RHS of the engine right now :?
PS '89
lax2wlg
Re: Terrano engine mounts
Post by lax2wlg »
99% sure its the same as the 86-89 Terrano/Pathfinder was nothing more than a D21 mini-truck with different rear springs and a camper shell rear body.
Are you looking for the bracket that bolts to the engine, the rubber mount or the bracket that bolts to the frame?
slide
Post by slide »
I'm also 99% sure the rubber mounty thing is same between navara and terrano (both with td27)
kbjj
Post by kbjj »
I used Terrano mounts when I repowered my 86 Navara with a TD27t, just had to grind off locating nipples (6 x 5mm long) on back of mount as it was in a different position. May or may not be an issue for you
Jeremy
kiwinoz
Post by kiwinoz »
Yeah, the rubber bit.
Thanks all.
kiwinoz
Post by kiwinoz »
D21 td27 Navara mounts are the go. left and right anyway, dunno about g/box.
Crash bandicoot
Post by Crash bandicoot »
yeap same as mistral too. based on D21 chassi
