Stripped all tyres of rims and got all the mud and sand out of the rims,
I was loosing too much air ( So much that I had a flat last weekend in woodhill ) ..
Noticed Rear brake pads have worn down heaps since last time I checked
Friday : Work was dead as , So up went the Safari on the hoist,
Fixed rear tail pipe that I ripped off a few weeks ago in the bush .
Made it sit up higher and finished behind the rear bar, so hopefully this lasts longer than factory, and previous quick fix
Started to replace rear brake pads, thought I'd meassure my ok looking discs, they were .6mm Below spec , and all my vents in the disc (Vented discs - Rear of Y60) coverd in sand and mud!.
So threw Away the Disc rotors, New Rotors and Pads
Removed the rear heat sheilds , should clear mud and sand better than before ( Have removed front heat sheilds when I did Diff seals and they do clear mud /sand much better than with them on.)
Flushed out all the brake and clutch fluid, Greased up the driveshafts .
Checked Bearings, wheel nuts , any leaks etc .. All is Ok ,
Ready for Wheeling in the Sand dunes tomorrow .
Sunday - Free tickets to the v8s at Hampton downs, will go for a lookie,
maybe I can pick me up a spare LS2 or LS3 / what ever they run in them touring cars . Would be a cool engine in the Safari
