1KZ-TE Instrument Cluster wiring diagram
bronx89
Post by bronx89 »
Does anyone have one they could share the link for pls?
evolution02
Re: 1KZ-TE Instrument Cluster wiring diagram
Post by evolution02 »
You will struggle to find any accurate wiring diagrams for a kzn130.
What wires are you trying to figure out as is easy to figure out most on these simple dashes. You trying to find temp sensor, speedo signal or something?
bronx89
Post by bronx89 »
evolution02 wrote:You will struggle to find any accurate wiring diagrams for a kzn130.
Really? Why's that? Damn.. really just need the whole wiring diagram for the entire instrument cluster for a mate of mine.
If anyone has one or knows where to source one please do share, thanks.
mudbugga
Post by mudbugga »
Try on here. There might be something that helps.
http://www.toyotasurf.asn.au/techsite/index.htm
bronx89
Post by bronx89 »
mudbugga wrote:Try on here. There might be something that helps.
Thanks for the link. Had already looked there but had another look anyway - couldn't find anything.
jonossiksilvia
Post by jonossiksilvia »
bronx89
Post by bronx89 »
Think I have already come across that but not sure cause I can't read any of the writing on it :twisted: , if it is then not what I'm after. Thanks. Is combination meter the same thing as the instrument cluster though?
jonossiksilvia
bronx89 wrote:Think I have already come across that but not sure cause I can't read any of the writing on it :twisted: , if it is then not what I'm after. Thanks. Is combination meter the same thing as the instrument cluster though?
yes same thing.
would of posted it up as a pdf but cant post pdfs to this site (would of been bigger)
bronx89
Post by bronx89 »
Ok sweet thanks will try searching around using "combination meter" instead of instrument cluster. See what I can find.
I actually think that image you posted up is the wiring diagram for the speedo cluster - could you please upload the PDF version of the page? Could use www.mega.co.nz or PM it to me? Or via email?
Thanks mate
jonossiksilvia
bronx89 wrote:I actually think that image you posted up is the wiring diagram for the speedo cluster - could you please upload the PDF version of the page?
Thanks mate
Thats why i posted it up as its for the cluster
pm me ur email address as cant post pdfs to this site
bronx89
Post by bronx89 »
Yea I couldn't see that, looked like the other garbage I'd found. PM sent.
wjw
Post by wjw »
Who knew Prados could fly?
jonossiksilvia
Email sent
bronx89
Post by bronx89 »
Have that manual - no help there unfortunately! Thanks though.
Cheers for the email and PDF, will have a look tonight when I'm home - thanks.
