-Landcruiser rear diff 9.5" 4.11 ratio with ARB locker = made a mistake on ratio
-Landcruiser rear diff VDJ79 9.5" 3.9 ratio (V8 flatdeck/5 door)) LSD
-Landcuiser 79 series (V8 or 6cyl) rear diff housing bare
-Landcuiser 79 series (V8) front diff housing bare x2 -(locker and non locker)
-Landcruiser 1hz complete running engine with starter and alternator
-Landcruiser 80 bare chassis - no plates
-Landcruiser 80 front diff complete - flange to flange - non locking
-Landcruiser 80 rear dif complete - non locking
-Landcuiser 60 rear diff complete - semi floating
-Surf YN60 solid axle bare chassis with rego on hold
-LN106 shortened wellside with custom towbar and rollbar
-LN106 wellside with toughdeck - dented but useable
-LN106 double cab shell, doors, interior etc - complete
-LJ78 prado rolling body - no diff heads, motor or box rego on hold
-LJ78 factory rear locker 4.88 diff head - needs rebuilt
-LJ78 rear diff housing x2 (locker and non locker)
-YN57? 2wd xtra cab same shape as LN65 bare shell, has all glass
-LN65 2.4d (roller rocker) extractors
-LN/KZN130 IFS front diffs - 4.1, 4.3 and 4.88
-KZN185 R151F 5 speed gearbox only - no bellhousing or transfer
-KUN series hilux or "Sheep shagger" factory steel winch bar
That will get the ball rolling. Have various other parts from LN65, LN106, HZJ70, HDJ80 and can scratch up a few FJ40/45 parts aswell so ask if there's something you may need. I may take a day or two to reply but parts will be sold on a first in basis.
Cheers Marc
