Temp Gauge not working
tintin
Post by tintin »
Just wondering if there is any easy way to tell if it is the dash gauge is not working or the sender unit not working anyone know what to do with out spending too much money on it would be great
Cheers Q
1980 4x4 Hilux Restoration Image
Re: Temp Gauge not working
if you earth the sender wire the gauge needle should read max temp
fullthrottle
Shuttle Queen
Post by fullthrottle »
If you have an ohm meter. Measure the resistance across the sender. It should change as the temp changes.
It will tell you the sender is working, but not exactly if its still accurate.
You would need the workshop manual to determine resistance at different temps.
Might just be a loose connection. Check that out too.
tintin
Post by tintin »
Sadam_Husain wrote:if you earth the sender wire the gauge needle should read max temp
Cheers Sadam, i earthed the sender wire and the gauge went up
so i take it the sender is stuffed?
skidmark
Post by skidmark »
correct, one faulty sender.
