diff ratio
mayhem1982
diff ratio
Post by mayhem1982 »
this may be a silly question but how do i tell what ratio a surf diff is on a truck that doesnt have the body tags on it?
mudlva
Re: diff ratio
Post by mudlva »
most accurate is to pull the head and count teeth
otherwise mark stud plate tdc on booth sides and pinion tdc
turn both stud plates simultaneously and count turns until the pinion does one full rotation then maths one what the ration is
quite easy for 4.1/1 but when you are getting 4.3-4.5-4.8 the areas can start getting a bit "greyer"
mayhem1982
Re: diff ratio
so just found the tag in the glovebox
just done a search
its a g254
so am i correct that its a 8" 4.55?
imsohi
Re: diff ratio
Post by imsohi »
yea this is a 4.55 diff open 4 spider
mayhem1982
Re: diff ratio
thanks
