Ln65 Hilux gearbox options
slognad
Post by slognad »
I've blown up my G52 gear box in my LN65 and i'm wondering if anyone knows what gearboxes will line up to my 3L (was a 2l). Like the R151f etc, if it wont bolt up why not?
Duncan
ToyRover
Re: Ln65 Hilux gearbox options
Post by ToyRover »
the rseries boxs fit the motor but think crossmember needs mod and the 4wd is electric and my be drive shaft mods,
slognad
Post by slognad »
Cheers, if i cant rebuild the box i'll get one and find out if it fits, the drive shaft plates look the same from what i can see
elvis
Post by elvis »
I've put a r150 out of a 2lt surf into my ln106,I had to use the crossmember from the surf and it bolted right up,I had to file out driveshaft flanges a fraction to get them to line up, transfer case is electric I had wired Myne up but I've gone through 3 electric motors already so I'm going to have to change that.
Smurf
Post by Smurf »
W56 out of an LN61 Surf will also bolt up. But the hole in the trans tunnel for gear levers needs 30mm taken off the back to allow the transfer case lever to work. No electric on a W56 either
W56 is supposed to be stronger than a G52, but not as strong as an R series box
slognad
Post by slognad »
I used a LN130 box, went in fine just had to do some wiring for the 4wd. nothing really any different
