KZJ78 height Specs.
Henry
KZJ78 height Specs.
Post by Henry »
Hi
So after consulting google and looking around I would like to know the standard Height of a KZJ78.
Or can someone with the original springs tell me the gaps at the front and rear diffs between the bump stops and the diffs?
I am trying to work out how big the spring lift in my truck currently is.
Thanks
jagni401
Re: KZJ78 height Specs.
Post by jagni401 »
LJ78 standard height
Rear diff to bumpstop 85mm
Front diff to bumpstop 35mm
