Moved to Christchurch, need help.
a80crewza
Post by a80crewza »
Hi all. I have moved to chch for a bit to work.
Also need advice/help with something. Recently had the turbo taken out and put back in and now have an oil leak. The guy must not have tightened it all back up properly.. Thinking the leak is coming from the oil return pipe?
Is it a hassle of a job? Can anyone help me with locating this and fixing this?
Cheers.
ClassicCruiserSpares
Re: Moved to Christchurch, need help.
The return pipes are prone to cracking when removed but also the metal gasket between the pipe and block are crap also and are better replace with the fibre ones.
Make sure your truck is under lock and key and is alarmed , a gps tracker would be useful ...
a80crewza
Post by a80crewza »
Cheers for the replies. Yes, I am aware of the theft problem in chch and am sussing something out.
Can anyone help me fix my problem though? I dont know what to do..
THanks.
go see 4wd accessorries he help you out
IcedJohnno
Trailer Trash
Post by IcedJohnno »
coxsy wrote:go see 4wd accessorries he help you out
I saw today, Ricks building is now painted up all red with RAC Ricks Auto Centre signed up. Still the same shop and the 4WD Accessories sign is still outside.
www.ricksautocentre.co.nz pulls up the 4wd Accessories website.
His address is;
34 Watts Rd
Sockburn
Christchurch
Phone 0800 4WDACCESSORIES
or 03 365 1909
rick@4wdaccessories.co.nz
petefj40
Ms Daisy
Post by petefj40 »
Or Kaiapoi Repowers & Repairs.
14 Stone St, Kaiapoi
Ph: 03-327-5317
Ask for Nathan or Cori.
:D
SamLogan
Post by SamLogan »
it is a bit of a hassle as the feed and drain both run into the bottom of the turbo. If you have a body lift it does make it easier to get to but it is still not that hard. Genuine replacement ones are what you want so go see toyota. Last i heard they are about 200ish. If you know how to use a spanner and have a bit of free time i would do it yourself. Its not hard but fiddly and much cheaper to do if you can do it yourself. The hardest bit is undoing the banjo bolt for the oil feed on the block. It is stuck between the block and the dump pipe
Sam
