The opinions and viewpoints expressed by users of Offroad-Express Forums are wholly their own and not necessarily those of Offroad-Express. https://www.offroadexpress.kiwi:443/Forums/
IT's a cool truck and a good concept...if your a builder...working in the okavango delta in africa. In need of protection from local tribes with ak47's and hand grenades... but if there is one thing the yanks know how to do, it's build military machines...plus there are probably more parts laying around in the deserts for a hummer then a G wage'n , IF you've driven tractors, especially some of the earlier european 4wd one's you'd lknow portal axles will snap off just like any other axle. for the sake of an extra six inches just drive through the obstacle as apposed to over it.
I mean let's face it...it's about the Look at me, look at me factor as apposed to actually doing anything with them
Re: im in love, AMG 6X6
Posted: Tue Feb 10, 2015 8:05 pm
by mercutio
I would much rather be in a military G wagen than a HummVee. Many more years under the G wagens belt and in use by many more military organisations including the U.S. Marines
Posted: Wed Feb 11, 2015 2:05 am
by lax2wlg
Nahh the M998 HMMWV is a million times more mobile, dependable, reliable and serviceable than the Mercedes. Can tell you first hand they are easy as hell to work on.
The HMMWV was revolutionary purpose built war machine whereas the Mercedes Gelandewagen is just a 4wd with diff locks that capitalises on Mercedes' reputation as a 'premium' automaker.
Name another production vehicle with these features:
-18" ground clearance -60 percent slope-climbing, 40 percent side slope and 60-inch (thats over 1.5 metres) water-fording capabilities -2.4 ton payload capacity -6 feet tall, 7 feet wide, 15 feet long - pretty much impossible to roll over -Modular design allowing for 15 different configurations -Inboard disc brakes -Fully boxed chassis with lightweight aluminum body panels -A diesel V8 engine -Positively pressurised and fully sealed drivetrain -Coil sprung Fully independent double a-arm suspension with hydraulic double acting shock absorbers -Full time four wheel drive with torque biasing diffs that lock up on demand -Geared hubs (not complicated planetary type portals) offering a final drive reduction of 2:1 directly at the wheel -37x12.5 tyres (optional 40" tyres) with Central Tyre Inflation System with run-flat feature
Plus because of the independent suspension, you can drop them out of airplanes.
Its really a silly comparison. The G Wagen is more akin to the military Jeep.
Posted: Wed Feb 11, 2015 7:20 pm
by MihiT
When I think Mercedes and off road, i think Unimog.
Posted: Wed Feb 11, 2015 8:22 pm
by mercutio
i was just about to say a unimog has specs more like those listed
Posted: Mon Feb 16, 2015 7:07 pm
by lax2wlg
Yeah but the Unimog doesn't have the mobility or survivability factor that makes the HMMWV so legendary.
No doubt its a heavy duty machine and great for schlepping around troops and supplies but poor dimensions and can't be operated at speed (and maintain control) due to the tremendous amount of unsprung weight in the planetary axles. The types of terrain that a HMMWV can be operated in will put a Unimog on its lid at a quarter of the speed.
Also when they add proper ballistic/explosive protection the weight of the vehicle gets to a ridiculous level which again compromises its mobility.
