kzn185 lift problem
Posted: Tue Mar 05, 2013 4:56 pm
by surfee
ive just been told that if i lift my truck any more then 35mm the front spring will hit the upper arm does that sound right?
Re: kzn185 lift problem
Posted: Wed Mar 06, 2013 12:39 pm
by floatingkiwi
No that's bollocks. I've got a 2" and a bit lift in the front of mine and it's brilliant, but CV boots aren't lasting particularly well! 2" is a good height to aim for. Call me if you like 02102410351 I've done extensive research on 185's.
Matt
Posted: Wed Mar 06, 2013 3:53 pm
by surfee
hmm weird i went to autolign and one of the guys said that anything higher then the 35mm will foul up the upper and lower arms and will need to have custom ones made?
Posted: Wed Mar 06, 2013 10:03 pm
by Cass
If that was true then it wouldnt leave alot of room for standard suspension travel, mines also lifted 2 inch an its all good
Posted: Thu Mar 07, 2013 5:38 pm
by madlux
Fool doesn't know what he is talking about, I've lifted one with a 2inch lift no problems. And plus there is to much clearance are the strut to even think about binding up......
Posted: Fri Mar 08, 2013 9:25 am
by bob_or_jim
2 words "Beam it" come to mind :D
Posted: Fri Mar 08, 2013 10:45 am
by Dirtydog
or make it SASey...
