toyota surf problems
lm61
Post by lm61 »
hey guys i have a 2.4 turbo diesel in my surf think its a ln106 not sure and when i start it in the morning it smokes like a b*tch and the idle is lumpy any ideas people? its semi white smoke not much black in it
and also when i change gear mainly 1st to 2nd then 2nd to 3rd it seems sluggish when i accelerate from changing gear.. any suggestions would be a big help cheers
imsohi
Re: toyota surf problems
Post by imsohi »
Sounds like your glow plugs need replacing
lm61
Post by lm61 »
is that why the slow response on the change of gear also? thaugfht it may have been the glow plugs cheers
nzlux
Post by nzlux »
Just after purchase I improved the performance of my hilux 2.8 non turbo diesel by simply putting in a new fuel filter.
If you have not changed your fuel filter in a while you might want to do that.
Ant
Post by Ant »
sluggish feel could be from head gasket on it's way out, mine started getting sluggish when under load then a few weeks later head went. try some radiator repar or head repair additives from repco and see if you still have the same prob after a few hundred kms, if it gets better then start saving for a replacement :( I think white smoke is a sign too. keep us posted, cheers
92 LWB Safari TD42
lm61
Post by lm61 »
just purchased the surf off a guy and he said the radiator was brandnew only done 20,000kms i will try some new glowies and fuel filter and some adatives..hope its not going to be the head as its my only car that runs for my family lol its got a pod filter on it and the airflow meter is loose just put into a hole in the inlet .... would that have a affect on being sluggish ?
lm61
Post by lm61 »
i wouldnt have a clue when last service was done either i am going to get that done get gbox and diff done at the same time too
bob_or_jim
Post by bob_or_jim »
Airflow meter?????? Either its petrol or it doesnt have an AFM. Mine dont that when the catch can (not factory) was full. Ide be checking the oil as the turbo may be pumping it out into the intake. If it is done let it run on its own oil or shell get away on you.
lm61
Post by lm61 »
its diesel mmmm il have to check that out later on its puzzling me aye i thaught it would have an airflow meter?
vinceparts
Post by vinceparts »
small little black thing in a cone shape may possibly be an air temp sender, can leave them dangling in engine bay if its wha ti think it is
lm61
Post by lm61 »
thats what it may possibly be as when i put a snorkel into my old surf we left that dangling out ..... now a tyre keeps going flat what a dud i think i thaught i was going to get a good deal
