I want to do something similar to what sibainmud did with the Terrano.
So I would like your comments the good the bad about the Isuzu Mu.
This is for all too comment not just people with Isuzu's.
Look forward to your replys
Chur
madlux wrote:The 3.1 can produce good power with a few mods. Ifs is shit like all ifs trucks are if fitted with big wheels etc... Rather the 3.1 over the Nissan 2.7 any day...
Sadam_Husain wrote:, post up what sort of stuff your thinking of doing to your truck
octanepwr wrote:What else are you planning to do to it? It looks fairly kitted out.
I have a 91 (2.on 33s, body lift, suspension lift, air locker rear, auto locker front, intercooler, 17psi boost, turned up fuel pump, removed muffler from exhaust.
Broken one CV at the front so far.
Snapped two rear body mount bolts (8.8 high tensile ones with captive nuts), had to get holes cut in the boot with gas axe to sort that out.
One thing I found was no easy way to mount a tow hook at the front. I dont have a bullbar (too expensive and no easy way to mount one from what I can see). I ended up putting a gusset over the body mount area and putting a hook on the side of that which seems to hold up. Have a chunky steel bullbar at the back with a tow hitch.
Have owned 2.8s and 3.1s and personally prefer the 2.8.
Yeah let us know what you are planning to do to it and what is already done.
