March 8th - 10th
Posted: Fri Mar 08, 2013 5:32 pm
by Camel
Payed up my insurance for the year on the Safari today .
Earlyer on the week , did a mini lift kit (2inch ) springs and shocks .
Replaced front broken bump stop with 80series Landcruiser (rear)
bump stops.
Really should do something about my front castor arms , castor mesurments out to shiet and bushes are stuffed .
Next on the list, shorten Pto drive shaft and install the controllers and start using it!
Hope for some rain so we can use our trucks in mud again
Re: March 8th - 10th
Posted: Fri Mar 08, 2013 5:39 pm
by luckyme
Posted: Sat Mar 09, 2013 8:03 am
by kbushnz
Well the plan is to do some more on the WTA intercooler install.
Picked up some 90 deg silicone elbows.. and a 2 to 3 inch exhaust tube adaptor. Mock it up and weld up the supports for the intercooler...
Just need to locate an inline fill point for the 19mm tubes...
Might go and visit my local plumbing merchant...
Edit: half way thru... Intake end mocked up and one support done . Time for lunch...Then do the second support... Will do turbo exit end later in the week.... Need to spend some quality time with the family
Posted: Sat Mar 09, 2013 9:01 am
by bigstu
Finally got my 3rz for the surf yesterday arvo
took it off trailer put in garage spent most of night staring at it trying to get a handle on what wires go where, spun the fan by hand and made some pretend engine noises
now to try and get a wof on the old girl before I pull the 3y out.
Posted: Sat Mar 09, 2013 9:04 am
by TJ
Got WoF sorted on the TJ. Good start to the weekend.
Posted: Sat Mar 09, 2013 4:11 pm
by kbushnz
Well its now just after 5 pm and I have finally got the WTA intercooler all tack welded in place.
Phew what a mish... Being a short ass trying to work on a lifted 4WD..
Need a step ladder to climb into the engine bay
Well thats the hard bit done.. Will pull it apart carefully and fully weld it all up....
Here is a photo to prove it. !
And yes the bonnet can still close with a bit of room to spare
Posted: Sat Mar 09, 2013 6:01 pm
by coxsy
Your not only one ,i use small stools to get to work hight with the safari.wound heat tape around fuel lines to shield them from turbo heat did part of turbo too
Posted: Sat Mar 09, 2013 6:12 pm
by sig
woo hoo
prado moved under its own steam today.have only got one gear thou
but at least it moves .Brakes are still "work in progress ",enough to stop ,just .probie did a quick vid ,havn't seen what its like yet .If its usable will upload
. will try and link these vids of its first movement under its own new steam
Posted: Sat Mar 09, 2013 8:04 pm
by scruff123
Went to welly's and traded the bighorn in on a 1995 fairmont to tow the mitsi, no more expensive rego! Then called in for a quick look at the drags in masterton. Put new cv's in the mitsi on thursday, jst need to weld sum brackets for the a frame and ill be sorted
Posted: Sat Mar 09, 2013 9:09 pm
by Ashohman
put holden v6 motor into hilux and took it out again and put it in again and out again then in again. long process trying to get engine mounts into the correct positions before getting them welded in then after they were welded got so sorting out my clutch got it bolted to the motor and bell housing on the gearbox and replaced slave and master clutch cylinders with new upgraded ones.
and tidied up the garage amazing actually some concrete under that masses of parts and rubbish.
Posted: Sat Mar 09, 2013 9:12 pm
by jetskiwi
Pulled some dash out and steering covers, to permanently wire in my digital egt gauge. Found to have flat batt, seems to be a problem now I work 3min from home.
On charging, one cell is fizzing, is that end of life ?
Also pulled auto aerial, but works ok, so must be the dodgy Chinese stereo, so that's out now too.
Still made it out to help with a seahorse fish after work.
https://www.dropbox.com/s/0ka3bud192iddg9/SandDriveSml.jpg
Posted: Sun Mar 10, 2013 12:55 pm
by coxsy
wife went out today to do the reg on the safari. she cant doen't have a wof. and i looked its true, funny i paid for one no sticker, nothing on the system.
chat time tomorrow ffs
Posted: Sun Mar 10, 2013 8:59 pm
by Camel
Debeaded tyre of rim . easy fix .
Used up alot of petrol - expected with a TB42.
Get home all good, wait a minute, alot of camber in front wheel,
That's not right for Solid diffs..
Posted: Mon Mar 11, 2013 3:10 pm
by Ashohman
Camel wrote:Debeaded tyre of rim . easy fix .
Did you go out to Muriwai Beach? You didnt happen to take a guy by the name of Rui with you?
Posted: Mon Mar 11, 2013 6:47 pm
by Nigel Bannan
Had the Basil Philp's Challenge on sat. Great day for all Combined Clubs and a day trip up the Gary and then down Okuku back to camp site on Sunday. Looking forward to next year with Canty Rec Club running the challenge. Nig
Posted: Mon Mar 11, 2013 7:28 pm
by L-andy
It was a great day Nige, thanks to all who helped organise it. You even had Land Rover beer at the bar in the evening :0) We missed 2nd place by half a point, gutted!
Garry-okuku trip following day was good as well but never seen it that dry.
Andy
