i have a 93 niassan terrano, its got a 2" body lift, ive had to wind the torsion bars to get it sitting level for some reason. I want to do a suspension lift so i have 2" springs for the rear & am wondering how to get more height in the front as the torsions are wound right up.
suspension
Re: suspension
fully111 wrote:i have a 93 niassan terrano, its got a 2" body lift, ive had to wind the torsion bars to get it sitting level for some reason. I want to do a suspension lift so i have 2" springs for the rear & am wondering how to get more height in the front as the torsions are wound right up.
Welcome to ORE
sounds like you need to re-index your torion bars
http://www.nissanpathfinders.net/forum/ ... on+%2Bbars
that link has full instructions on how to do it
with photos as well
Alex
Re: suspension
Re: suspension
Awesome.
Re: suspension
1 more thing winding the torsion bar to the max without doing anything else to the suspicion am I likely to have problems down the track
Re: suspension
fully111 wrote:1 more thing winding the torsion bar to the max without doing anything else to the suspicion am I likely to have problems down the track
Winding to max is considered a 'poor mans lift' (not my words) and will lead to problems quickly. Winding an inch or so and you'll generally be ok. Throws out the suspension and steering geometry, so the components won't be operating at the angles they were designed for. This can have a domino effect...
Many go 3" bodylift only, no sways and have minimal front problems
Others go 3" torsion crank and have catastrophic problems
Re: suspension
If you just wind the torsions up without doing a diff drop the C.V.'s will run on a bigger angle which will cause them to wear out faster and may break easier.
Re: suspension
i went the way of 2 inch body lift, and 2 inch suspension lift and wish i just did a body lift and cut guards etc.
i was running smallish 33's for about a 6 months and constantly having problems.
i had alot of problems with winding the torsions up, main one was not much articulation and a hard ride.
i also went through cv boots like nobody's business, aswell as bent/snapped tie rods.
this was before i knew about all the other stuff like idler brace, etc to make it sturdier, just keep in mind your re designing the front suspension geomety.
i definitly recomend a diff drop, and dont bother running anything bigger than 32's, unless you do beef up the steering.
theres several ways to beef up the steering, from simply making a brace for the idler arm, to replacing most of the system with that out of a 2wd navara.
Re: suspension
Sibainmud's truck is a great example of 'just enough' torsion crank and essential steering mods (hoohaa type centerlink, idler brace). Could be wrong but I don't believe he's done a CV yet...
Problem is you can't really diff drop these like you can Toyota IFS. The torsion bar pivot is on the lower control arm and gets in the way. So only about 1/2" is possible.
True zukmeister, its the wonderful world of IFS! CV angles are always at the front of your mind, and boots, well, same deal. I'd check the boots before each trip. Manual hubs make them last a lot longer, I think sibainmud also had a trick of stretching them down the axle shaft further so the ribs don't touch as much.
Dirtydog you still haven't posted videos/photos of your vehicle in action!
Re: suspension
didnt have any back then, and still working on those flares.
trust me i wish i could, i would have photo's of it up towards macetown but had to stay down due to my dammed tooth needing pulled out.
im waiting for the other truck to sell and then i will be able to finish the neccesary things on the 'ranno... first thing is longer shocks...
but anyway, back on topic.
