terrano starter motor removal
Hi anyone got any tips on how to get the starter motor out of a diesel D21 terrano.....had a quick look and it looks like it could be a pain.
Re: terrano starter motor removal
I went in from the top, removed p/s reservoir & bracket from the body & pushed hoses aside to get access.
Like anything, long and short sockets, a variety of extentions, ring spanners also a variety of crows foot, plus some extra skin for your knuckles...
its a prick to get out by the sounds of it
Get a body lift, out and in 1/2 hour
On a serious note, prick of a job. I find the best way to get at bottom bolt is to come up from under with a few long extensions and a uj. There is a sweet spot over front diff and under the engine mount.
Best of luck.
Best of luck.
undo right engine mount, tilt engine over wouldn't work?
Get creative with extensions and swivel joints, and spanners. After starter unbolted, tie a bit of rope to it, use rope to lift it up out the gap next to brake booster/inlet manifold. Take note of the way it comes out, lower it back the same way. If you think its bad, try a v6 terrano
slide wrote: If you think its bad, try a v6 terrano
And if you think thats bad try a V8 hilux
See that little hole in the back of the valley? thats where it sits and the 2 bolts that hold it in come from the firewall side
- Bush Crasher
lax2wlg wrote:I went in from the top, removed p/s reservoir & bracket from the body & pushed hoses aside to get access.
I took the front right wheel off and went there.
Wasn't too bad at all really - well compared to say a P10 Primera where it's on the LHS of the car and the only way to reach it is to remove the RHS wheel and you have to do the whole job with only one hand and you can't even see it.
im sure ive done a few at work, and as they say some extensions and universal and spanners, then pull the starter out the top close to the brake booster by memory?
