Wanting to get diesel pump tweaked
hachi_roku
Post by hachi_roku »
Hey,
Im wanting to get my truck tuned as such, wanting to get pump tweaked/dyno'd for tune, not for hp and make sure everything is working as it should. Who in auckland does this and is resonable
Its an 80 series, 4.2 turbo
4WDbits
Re: Wanting to get diesel pump tweaked
Post by 4WDbits »
Alltech in Glenfield are good http://www.turbo.co.nz/alltech/index.php
badnuz
Post by badnuz »
X2 for alltech
use an anoroid valve from a 4M40 Mitsi pump, helps with off boost over-fueling too.... (means you can wind more fuel in for boost :) )
get them to mod your CT26 while its there too, more boost at lower RPM :)
wopass
Post by wopass »
12mm ring spanner and a small blade screw driver, half an hour and you have done it yourself...
http://lcool.org/technical/80_series/1h ... p_adj.html
:mrgreen:
xj
Post by xj »
Wop, is that applicable for the 1hd-t as well, or just the 1hd-ft?
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
hachi_roku
yeh i spoke to alltech a few months ago regarding the same thing.. but they tried to tell me that they need the pump off etc to check settings. Im wanting someone to tune the truck, make sure fueling is ok.. mine seems to be a little fuelie at idle etc, im not wanting all out power etc, im just wanting it to run a best as possible.
there is a 4x4 dyno place on great south rd penrose auckland seen the place a few time but not long enough to get a number
T-mo
Post by T-mo »
x3 for Alltech. Great service and advice. Reasonable prices too.
Tomo
1991 Nissan Safari AD SWB TD42 - 33x12.5 BFG KMs, 2" lift + more coming.
"Never let a nerd loose with a torque wrench."
xj
Post by xj »
mine got the tweak today, 20 mins with the nose in Wops garage and it was done...... And yup, it makes a heck of a difference.
Cheers Wopwop.... Next time ill bring the boost tap and gauge too!!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
wopass
Post by wopass »
churr churr
:wink:
85bj71
Post by 85bj71 »
Is there anyone in christchurch who knows how to do said pump "tweak" or can send me in the right direction of somone locally who can?
xj
Post by xj »
Try flicking Turoa a pm dude
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
