clicking breaks?yn65 surf
justin
Post by justin »
Hi all , every time i put the breaks on i hear a click from the front , also hen going over bumps on the road i hear it repeat , but when i go over the same road with the breaks on ( just a bit it is gone) something loose for sure,
any help ould be great.
justin
slide
Re: clicking brakes?yn65 surf
Post by slide »
Sound like just one side doing it? Get under truck and have a good look at all brake mount bolts, pads, slides (if single piston callipers), rotors (no cracks) and even suspension ball joints. Hopefully if theres something amiss you'll spot it easy
Nath
justin
Re: clicking breaks?yn65 surf
Post by justin »
thanks man, it was the brake pads on both sides there is a bit of play were the pins have increased the diameter of the hole , sounds dodgy as but as told not to worry about it , heaps of meat left so ill just put up with it i guess till i need new brake pads, or try and get rubber washers but may not mess with them if its just a noise with no real issue
thanks tho mate
