the elusive w58 bell housing
spanky
Post by spanky »
is there different bolt patterns on the motor side of a w58 bell housing, as i have found a heap in aus but they want to know what motor do i want to bolt it to. and is the 1g motor same as the m series bolt pattern cheers vaughan
SupraSurf
Post by SupraSurf »
NuTTa
Post by NuTTa »
if you want to put the 1g in i can supply a flywheel,clutch plate/pressure plate and bellhousing, there is quite a difference between the two for the 1G and 5M.
Brendon
spanky
Post by spanky »
mate that sounds real good, i will know on thurs if i get the motor and will contact you then, much appreciated cheers vaughan
