Got a 1994 pajero 3.5l swb. When i turn the truck on i have good power and response for a few minutes then i lose all power when i put my foot down the revs don't go up much and i slowly pick up speed, but if i turn the truck off then back on it is back to normal for a few minutes.
Anyone got any ideas?
Auto trans issue
Re: Auto trans issue
O2 sensor failing....??? Will run gutless when they pack up... But will idle and rev freely un loaded. But when loaded.....Gutless
kbushnz wrote:O2 sensor failing....??? Will run gutless when they pack up... But will idle and rev freely un loaded. But when loaded.....Gutless
How can i test this?
Got the computer scanned today and came back with error code 32 to do with the auto transmission
Does anyone know what that code is for, so far my searches come back a temp sensor or a solenoid.
Could be that the temp sensor is reading that the gearbox is too hot, and putting it in limp mode (starts off in second etc) which could be faulty sensor.
This might be of some help:
http://www.pocuk.com/forums/viewtopic.php?t=101720&highlight=auto+fault+ecu
94 Pajero SWB, 3.5 V6
