Toyota 5L/ 3L oil cooler sandwich plate? Z334 filter size
Posted: Sun Apr 07, 2013 10:20 pm
by ajthompson
Hi! has any body had any experience on fitting an oil cooler to 3L or 5L engine?
i can't seem to find the right size sandwich plate to fit one.
Re: Toyota 5L/ 3L oil cooler sandwich plate? Z334 filter siz
Posted: Mon Apr 08, 2013 4:02 pm
by kbushnz
ajthompson wrote:Hi! has any body had any experience on fitting an oil cooler to 3L or 5L engine?
http://www.ebay.com.au/itm/OIL-COOLER-S ... 0819776394
Posted: Mon Apr 08, 2013 6:18 pm
by tweake
just be carefull that you actually have room for it. ie filter doesn't run into steering or chassis. otherwise you will need to do a remote filter setup.
the other way is to change to the hiace version which has the filter vertical. also the z9 version is easier to get adapters for.
Posted: Tue Apr 09, 2013 8:20 am
by ajthompson
Awesome. Thanks!
Posted: Tue Apr 09, 2013 8:23 am
by ajthompson
tweake wrote:just be carefull that you actually have room for it. ie filter doesn't run into steering or chassis. otherwise you will need to do a remote filter setup.
This is for a hiace so already have the verticle filter. So should be heaps of space!
