more power out of 2.5 diesel turbo ford courier
Posted: Tue Apr 09, 2013 6:47 pm
by ratbagjamie
has any one done any cheap simple mods to one of these engines to get more power with out going over board? I feel its gutt less in 4wd hi when off roading?
Re: more power out of 2.5 diesel turbo ford courier
Posted: Tue Apr 09, 2013 7:10 pm
by zukmeista
Use low range instead maybe?
Posted: Tue Apr 09, 2013 7:42 pm
by coxsy
used the boss's 2wd turbo diesel today, more stick than my std 2.5 non turbo, see if they have boost pressure release block that and try find the fuel screw
Posted: Tue Apr 09, 2013 7:45 pm
by hamboy
These things can be lifeless below 2000rpm, make sure the fuel and air filters are up to date, then get rid of the EGR system.
Posted: Tue Apr 09, 2013 8:02 pm
by NJV6
hamboy wrote:These things are lifeless below 2000rpm
Fixed it...
Just have to drive them between 2000 & 3500 for best results, done lots of km in them, as soon as offroad, into lowbox as zuk said.
Just got to keep them boosting cos when they are they got heaps of grunt.
Posted: Tue Apr 09, 2013 8:23 pm
by ratbagjamie
yeah I had to use low up the beach just want to get more out of it
Posted: Tue Jun 11, 2013 10:03 pm
by 44jetboat
brother had a 2.5 2wd. we blocked the egr installed large front mount intercooler and played with the injector pump. uped the fuel and boost compensator. went really well after that. set the max ext temp to 700deg pre turbo. just to be safe.
