Evening ORE,
I am looking at moving to 35"s and want some input as to what my 33" muds are worth, all are 33 x 12.5 x 15
2x Goodyear Wrangler MTR
both with even wear at 9mm.
These are the "old" desirable tread pattern.
4x Mudstar Radial MT
8mm, 5mm, 6mm & 7mm. (one has uneven wear but drives fine.)
Hopefully Skid & Bolo can comment on this too?
Photos: http://imgur.com/a/4ZADB
What are my 33"s worth on the 2nd hand market?
Re: What are my 33"s worth on the 2nd hand market?
you $1 reserve...... hard to guess market value, auctions go nuts in the last hour or so....
- Suza
Not enough from my experince
- skid
- Tyre Man
CLUMZ1 wrote:Evening ORE,
I am looking at moving to 35"s and want some input as to what my 33" muds are worth, all are 33 x 10.5 x 15
I do believe they will be 33/12.5 R15 not 10.5 wide as you have said.
What JD said, the market tends to determine the value these days.
I will measure a new one tomorrow, but I'm fairly sure they are around 13mm tread depth when new, so yours are about a 1/3 - 1/2 worn.
So if new ones are say $300 then in theory you could possibly get $200 but in reality they are probably only worth $100-150 per tyre.
sorry dude but this seems to be the going rate these days
- Dr_PC
If you get offered $100/tyre then grab it with both hands
Dan
Dan
im keen on just two if u separate bro
poor little suzuki
guessing that you're referring to the pair of Wranglers?
its a bummer your so far away other wise i would be interested.
